Hey Guys and Girls
I am just about ready to scrap my whole project as no one has any idea how to fix my problem.
I have an R34 GT Sedan which was 2L Non turbo auto..Which I have replaced with a RB25DET Neo out of a Stagea and converted to manual. We have have used the ECU from the stagea and have re wired the loom and basically the car is drivable.
The car is drivable with a "Normal" driving style eg..normal gear changes and normal accelleration. The problem arises when we plant foot. at about 3500rpm with the turbo at 8psi the car loses all power and dies untill the revs drop abit then all power returns and its drivable again. With the same thing happening if you plant foot again.
We have plugged some equipment into the consult port and basically the story is that at the exact point that the power cuts the afm is maxed out and the injector cycle cuts...
We have used the afm from my RB20DE out of my r34 and it is pink sticker(Same as GTT) so thinking that it may be a faulty afm we tried one from an R34 GTT and an R33 25DET and same story(Maxed out)...We have checked for boost leaks and nothing. checked the voltages at the afms in both my car and a GTT at idle and 2000rpm and both readings are exactally the same so why is it maxing out when the turbo spools up?
Im really hoping someone can help me out as this problem is stopping me getting the conversion certified and having my car back which has been close to 5 months.
Please help me...I really want my car back running as it should be.
Cheers.
https://www.sau.com.au/forums/topic/307105-rb25-conversion/
if the AFM is maxing out what do you expect the ECU to do?
of course its going to panic and dump all the timing etc, its a standard protection mechanism
it would seem unrealistic that you would max out a stock ER34 GTT AFM
are you sure its reaching 5v and flat lines? does it ramp up linear or instant ramp to 5v?
maybe something else is wrong with the AFM control circuit?
with key to ON but engine not running AFM should be sub 0.5v and at idle it should be 1.1v
a bog stock ER34 GTT with a stock ER34 AFM Will not max out, so something is fundamentaly wrong
either your AFM is mangled, the wiring is mangled, your ECU is mangled or you are looking at incorrectly
https://www.sau.com.au/forums/topic/307105-rb25-conversion/#findComment-5074488
The diagnostics are telling us that it is building voltage as it should when accellerating but the minute you plant foot it hits 5v and it cuts out. We have compared voltages and everything to the gtt that we had with us yesterday and everything is identical....
https://www.sau.com.au/forums/topic/307105-rb25-conversion/#findComment-5075129
I'm taking it the Stagea was auto trans right???
Maybe has something to do with the auto ecu u are using as the engine and trans computer are built in that one unit with the Neos
I know in the R33 the auto ecu will run with the manual conversion done but not sure about the in the R34
Should try a manual ecu
https://www.sau.com.au/forums/topic/307105-rb25-conversion/#findComment-5075146
you're sure its the right afm right?
anyway....the stagea ecus have a really narrow band of tolerance to mods, and when you are off that they pull heaps of timing and richen up like crazy. first time I hit it I honestly thought I had blown a cooler pipe off it was so bad.
ubfortunately there is no easy way to swap an aftermarket ecu in there to check though, there were differences between r34 and stagea pin outs so you would need to find one pre-modified to the same ecu model that you have.
https://www.sau.com.au/forums/topic/307105-rb25-conversion/#findComment-5075933
If you use say 75% throttle, does it do the same, 90% throttle?
If no, there's a wiring issue, and it sounds like something is crossing up with the TPS sensor.
Edit: Simple test, with key switched to on, engine off, put the accelerator flat to the floor, does the AFM read 5V?
Edit: Just checked the wiring diagram, and there is the variable TPS read out, and there is an idle/WOT switch also.
I'd be guessing the WOT switch could be connected over to the AFM by accident if the above test yields a "yes, it reads 5V at WOT engine off"
https://www.sau.com.au/forums/topic/307105-rb25-conversion/#findComment-5076049
Thanks for the help guys I really appreciate it but we have found the issue...Im not exactally sure what the problem was but I am told that it had to do with the speed cut.
basically they sed that the ecu was thinking that the car was travelling a lot faster then it actually was eg.. 190kph so....long story short, a wire was chopped and the car is now fixed...
Thanks Again,
https://www.sau.com.au/forums/topic/307105-rb25-conversion/#findComment-5077314
im assuming the wrong speedo sensor was used in the conversion. perhaps your mechanic swapped the speedo sensor from your auto over not considering the ecu was changing also.
OR
maybe the manual parts came from another car and ur stagea motor was originally auto?
make sure you fill us in with this info for future search value.
https://www.sau.com.au/forums/topic/307105-rb25-conversion/#findComment-5077330
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
