ok i got myself a bit of a pickle here... a few months ago i found out that nizzpro performance did a 1jzgte conversion into nissans. so i went out and bought a r32 shell without a engine and diff which was pretty much all i was looking for. i got the money arranged yesterday so i went into nizzpro this morning to talk to them about exactly what it would cost etc.
so i asked the blokes there about it and he took me through the workshop, telling me the info that i needed to know. after a bit of discussion, he got me onto a rb25 conversion, both looking at it being a bit cheaper, it would only take a bit over a week compared to about a month and more power out of stock internals and is generally better. he seemed to dislike the 1jz conversion a bit more as well.
the original base offer for the 1jzgte with everything included and installed was $7500 (not including diff or suspension), but they've had to bump up the price a bit because of price increases in some of the items they buy to do it. but to get the rb25 in it will cost around the $7000 mark with everything i wanted (suspension and diff included).
iv been searching on the net this afternoon with 1jz vs. rb25 discussions, and everywhere i read that 1jz is a better engine both in potential and strength. so now im feeling very undecided. the car is just going to be a track/drift car so its going to be under the pump a fair bit.
what are your views on 1jzgte vs. rb25det? pros and cons for its intended purpose.
https://www.sau.com.au/forums/topic/307137-1jzget-vs-rb25det/
  • Replies 78
twin turbo 1jz or vvti 1jz? what gearbox?r154 or w58?
power wise, the 1j has it anyday on a pretty well standard engine.
they should really only take the same amount of time unless he doesnt have all the parts there.
either way just be a little bit wary of them
i bought a few things off them a while ago and it took them a long time to get me things id payed for. ie. 1 year later i received the last parts and at the time i had bought 2 rb25's and a shell from them so i was probably their best customer.
In my experience 1J is pretty much bulletproof when MAINTAINED and a hoot to drive no matter what its in just with bolt ons. X10 for the VVTi version
I suppose it comes down to if you want to commit to a conversion. Or just bolt in and go nuts
Some plus points for the 25 is of course bolt in, 5 Speed gearbox is cheaper, aftermarket parts avalibility, and short blocks are prob cheaper when it blows.
But if it was me, and I had the coin to do it properly it would be 1J all the way.
A better comparison is 1J VS RB26
Not really. Rb26 would be compared to the 2jzgte.
Rb25<1jz<rb26<2jz
$7500 for a RB25 conversion + suspension + diff
I'm assuming the suspension and diff costs at least $3000???
No way a RB25 conversion costs anymore than $4500 at the absolute most, even then that is a silly price.
Rb25<1jz<rb26<2jz
If you look at the pecking order, yes, thats how you would compare them.
But I believe that the 1J is a whole lot better then a 25. So not much point comparing them. Each to their own, but this is from what ive seen in front of me.
The day I see a 25 sit on the limiter for 3 minutes laying rubber is the day ill compare it to a 1J. I am no Toyota fanboy either, I own 3 skylines.
that includes exhaust, ecu, wiring, exhaust, labour, fmic, alloy rad, 2 way diff, few other bits that im missing etc.
1jz>rb25, but in your case, go the 25, easier, cheaper etc.
it sounds like he doesnt want to do the 1jz conversion, thats why hes trying to talk you into the 25, much easier for him.
theyv done a few recently and said that they'v lost a bit of money on them because prices have gone up on some parts. he was quite happy to still do it, just with his reasoning it seemed like the 25 was better
I think the Toyota engine is superior to the Nissan.
But you're doing a conversion so there's a lot more to look into than simply engine selection.
Before you make any decisions, have a close look at any 1 or 2JZ's installed in a Skyline or Silvia.
The exhaust manifold is on the opposite side to Nissan, so your brake and clutch master cylinders cop a lot of heat, especially as you've mentioned track/drift?
Exhaust will be dropping down in a very crowded area for any RHD vehicle.
You'll be paying someone for this work and it's obvious, the Nissan engine is the easiest (cheap/reliable) option.
engine quality the toyota engines are much better than the nissans.
as far as your conversion goes though, i would stick with the nissan engine as for the extra money that you save on putting the rb25 in you could do some upgrades to it and be better off.
however if it was me doing it, i would scrap the idea of using the r32 shell and just go out and buy a complete r33 gts-t and mod it. cost wise it is going to work out similar, considering the price of 33's these days and what you would get back from selling out the stripped parts. weight wise it is only a fraction heavier than a 32 (would only be a few kg's in it between a 32 with a 25 and a 33), especially once they are both stripped down to track spec. but as i said, that is the way i would go. you can do what you want
Just recently purchased a chaser (1JZ-GTE), and i must say its a better engine than the RB25. Stock vs stock the 1J is deff quicker. Well it feels like it. I have owned a skyline 33 (rb25) for 3 years, and now a chaser. Straight away i could feel the difference.
I would put a rb25 in that 32. Easier, cheaper and it will be less hassles.
I have just completed the rb25 conversion into the r32 - well worth it.
Car has more everything and the swap was pretty simple. From a part point of view the rb25 has it but from an engine point the 1jz
Maybe speak to afew people who have completed the 1j conversion and see what upsides/downside they have exprienced? It cant all be good :P
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
