couldnt decide where to put this, but pretty sure i've seen similar stuff in here.
before i get hung/drawn/quattered, i put this here instead of the vid thread coz its not just something to pass the time, but its a sweet bit of engineering/tech.
link
waitstobehungdrawnandquattered
cheers,
Ben
https://www.sau.com.au/forums/topic/307152-cnc-motorcross-helmet/
the that helmet is probly harder than most surfaces you would hit anyway.
cost i imagine would be prety scary
and therefore pretty shit at cushioning your head in an impact. your skull will be mushed, but atleast you wont have to get a new helmet everytime :)
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
