Car is completely standard other than wheels and tyres.
Rear tyres are 255 17's and are Bridgestone Potenza RE050A.
Other than slicks or semi slicks or wider/bigger wheels and tyres, what is the next step in improving traction? Suspension, camber, toe angle, etc..
https://www.sau.com.au/forums/topic/307167-maximum-traction/
all that you just mentioned. its not an easy job at all getting a RWD turbo that isn't set up for extra power to grip very well. you could adjust all the above, and you might still have issues with traction. depending on your engine setup. work through the list above, start with wheels, then start with camber/toe adjustments, then for track work possibly look into a better LSD.
sway bars are also probably the first point of call and most benneficial bang for buck mod you can do to any car. by reducing overall body roll through corners, the wheels/tyres will stay closer to their wheel alignment settings. a stiffer rear sway bar will reduce roll in the rear and leave the front wheels more evenly loaded so there can be more available grip in the front. also helps with tyre wear.
and when the lack of avilable grip finally starts to piss you off. get an AWD. i'v never looked back :D
Edited by DrewII
I would love to hear from other R34 GT-T owners who drag, specfic suspension setups that you found to work would be awesome!
Any other info would be great regarding traction, as drew mentioned, if i could get specific info on what to use that would be really helpful.
Considering your car is standard, it wouldn't really break traction unless you dropped the clutch really quickly. Launch nicely and it should take off well.
Camber can help give abit more traction. Your best option would be semi slicks but you don't want that. Its also your cheapest option. Get some Khumo ku36 tires.
I know a few people with 5x20kg cement bags in their boot to get more weight on the end. They don't lose much power but they do gain alot more traction.
My 240rwkw will never stay straight on high boost, I like it. I'm getting front and rear strut bars soon. That should help the car sit more flat and hopefully a little more traction. Next ill be putting the ku36 tires, I currently have the ku31's
Edited by SargeRX8
KU36 tyres offer very good dry weather grip for the money. terrible in the wet.
semi slicks will provide you a further benefit, but they have different degrees of wear and can be costly.
If your car is standard, i would go KU36 (roughly $200/corner for 17") + camber adjustments + thicker adjustable sway bars ($5-600 installed) FIRST. this will be the cheapest starting point.
then start adding more if you feel you're still lacking traction.
Edited by DrewII
strut braces dont do shit.... get swaybars
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
