I have a Drift Digital Boost Gauge to install in my r34 gtt.
So far Ive decided the follwing and am hoping to get some suggestions as to whether what I'm doing is right!
1. I'm going to mount the gauge on the A-Pillar, and have a found a space through the door frame to under the bonnet which I think would be nice to fit the wiring through.
2. I've located what appears to be the stock boost sensor.
I am not too sure about this part, but was planning on cutting the hose and t-piecing it to my new gauge. Is here where I should cut? Or am i being completely clueless here?
3. I also have to connect to gauge to 12V main power. My thought was to run the wire under the steering colum out of sight, and connect it to the 12V power which was used for the cigarette lighter (which I never use for anything).
Any help would be appreciated.
My last question is this, I found this switch while playing around, and i am not quite sure what it is. It is hard to reach and is near the driver's side door.
Any ideas? I thought it may have been a kill-switch, but doesnt seem to have that effect (or any it seems at this stage).
Cheers fellas.
https://www.sau.com.au/forums/topic/307185-r34-boost-gauge-installation/
Quick update a day later...
Installed all as described except found what I think it a better place to t-piece the vacuum hose.
All working smoothly :D
I'm thinking I may post a quick tutorial because I couldn't find any up to date ones with pics on the forums? Hopefully it may be helpful (although it was quite easy in the end).
Cheers.
  • 4 months later...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
