Hi,
Ive changed over my front bar from a series 1 to series 1 mspec. the reo stays the same. but for some reason the bar on the right side has slotted in perfectly and all i needed to do was put on bolt in the closest hole to the tyre. i also tried the left side and for some reason ive done both bolts and the second one closest to grill (not the tyre) was hard to get on tight because its in a hard place to tighten. does anyone know if i have to remove my headlights and insert the clip inderneath them or is there something else i need to do? because when i removed my original front bar there were no clips underneath the headlights.
ive attached photos
cheers
https://www.sau.com.au/forums/topic/307217-installing-new-front-bar/
There are 2 screws on the inside of the bumper which you have to reach for in your wheel arch, one is at the end of the bar near your wheel and other is just before your headlight, this one will pull it up to your headlight
