so after my boost gauge has been sitting on my desk collecting dust for a few months i decided i'd have a shot..
after about 5 hours googling, trolling forums etc etc i still cant work it out (i have no electrical knowledge at all) and im not paying someone $100+ for something that probably takes 30 mins to do.. (yes ive rung sooo many auto electricians, cheapest was $100/hr)
questions
1. seeing as i have 3 greddy gauges, can i tap the wires from that (ground, power etc?) The Greddy gauges have the same wiring as the "autogauge" boost gauge.
2. If im able to tap those wires, all i then need to do is tpiece the vacuum line, mount the gauge, thats it right?
apologies for yet another "boost gauge" thread :happy: I know nothing about wiring (im at the point where i need pictures of what i need to tap / wire up)
https://www.sau.com.au/forums/topic/307242-boost-gauge-install/
hey mate where are you located? if you have a greddy slim series you dont need to wire it in they use power off the exsisting gauges.. if your close to mt gravatt i'll give you a hand wiring it in if you want ... simple really hardest part is mounting it lol
im over in paddington / ashgrove area. I think mine are the slim series like the one attached except i only have water temp, oil temp, oil pressure. Not sure what you mean, i dont need to wire my gauge in it uses power off the existing gauges? (how does it get power without wiring in?) or do u mean is the boost gauge a Greddy slim series gauge?
did a mock install before i tried it
photo below, the 2 top bits (the wiring and the filter thing, i have no idea where the filter goes, and i think the wiring is just extra incase you want to have a warning light)
pic below is where one of my Greddy gauges is already wired up, black, red and white wire (this was my reason for the topic, can i tap those three wires?)
pic below is apparently the vacuum line (which runs into the black unit which is the stock boost sensor for the stock boost gauge which is right behind the drivers side strut tower)
anyone know if im on the right track?
Edited by defari
first pic.. those ms paint bits you added to ask questions.. even on 400% zoom i couldn't even make out what you wrote..
why don't you get power off the ciggy lighter or something inside your dash that uses power when the car is started.. that way your not taking lines all the way to the engine..
if you got a factory vacuum line.. are you still using the factory boost gauge? if not then use that instead of the line with your gauge.. if you are then just cut into it and install that tee (one you circled
ah ok its a auto gauge.. well its better if you run the 12V acc power off your stereo , earth it either near the fuse box the bolts that hold the bonnet opener , one connects to your illumination (dims itself at nite) , the other is constant 12V this can be used from your stereo , you can earth it using the steel caddy around the headunit ...
by the way just to let you know you shouldnt tap into the Greedy sensor wires as that will stuff your gauge reading .. thats mainly for the sensor to convert it from analog (vaccum) to digital pressure for the gauge to read...
why don't you mount the gauge.. hook up the +ve -ve etc wires that you know where they go.. then try bribe a workshop to hook up the last bit for cheap.. tht way you've done most of the work and they make a quick $$$ for little effort
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
