Self-explanatory. Pretty affordable after you sell the vodka that it comes with, as well as the gold and diamonds, I guess. Not sure if there's a market out there for second-hand whale foreskin though :happy: I don't even want to know how they sourced something like that. Out in the pacific ocean I hope there aren't a herd of circumcised sperm whales...
$2mil Bullet Proof SUV
https://www.sau.com.au/forums/topic/307253-holy-crap/
The seats are not for the squeamish. They are made of one of the softest materials around - leather from a whale's penis.
Moby Dick is up your ass and your can even see him muhahahaha
its called a dork... you dork.
https://www.sau.com.au/forums/topic/307253-holy-crap/#findComment-5076619
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
