Make/Model: HR31 GTS-X Coupe
Year: 1987
Kilometers: 114 XXX
Transmission type: Manual
Engine: R34 GTT RB25DET Neo
Colour: Black over Silver
Modifications: RB25DET Neo, Greddy Type LS FMIC, 3 Inch exhaust (Stainless front pipe, 3 inch highflow cat & muffler), Nistune Chipped ECU, HDi SBC-D Boost controller with Gauge, Z32 AFM, 550cc Injectors, GCG XTRGTST-STG1 Custom Turbocharger (uses a ball-bearing GT30 core inside standard RB25 housings) on heat-wrapped exhaust mani, Xtreme 5 puck clutch, Bosch 040 Intank fuel pump, Catch can, Gates radiator hoses, Apexi pod filter, 16inch thermo, standard R200 longnose LSD which is very tight. 16" Volk rims with good tread.
Roadworthy Certificate: Yes
Accident History: None that I know of, all panels line up etc and paint is original.
Asking Price: $7500 FOR 2 WEEKS ONLY
Contact Details: Call Hayden on 0422 903 269 , here or [email protected]
Other Comments: Selling due to some financial mishaps in my life, As well as loss of interest. this sale is alot sooner than I would have liked and I had many more plans in store for her. Basically I bought the car about 1.2yrs ago, completely stocko. All the mods were done while I owned it, and many thousands were spent modding it.
The engine was bought from another member on the r31skylineclub.com forum, and has performed flawlessly since i have owned it. The engine setup its running is fairly unique, so I will try to explain best I can on here: Its an RB25DET neo Engine, running the aforementioned turbocharger, with an R33 GTST (deletes TCS) inlet manifold + matching loom, and running the show is a Nistune Equipped R32 GTST Ecu. I wanted to build a car that did not look heavily modified from the outside, and drove & behaved as close to a stock rb-powered skyline as possible. This is why I went to such lengths to collect all these parts to produce this package. The wiring loom was professionally modified so it would simply Plug into the HR31 body plugs, and ALL ELECTRICS work!
VCT is fully operational, and is controlled by a custom RPM window switch I had made in the USA, switches VCT on at 1500 RPM and off at 4700RPM.
The body is in fairly good condition for its age, has 2 small dents and paint is showing its age a little. Interior is in good condition also. Has a pioneer MP3 head unit with pioneer splits in the front and kenwood 6x9s in the rear parcel shelf.
I bought the car with 107XXX Kilometers on it, and all mods except the exhaust were done in the last 5000 k's.
She produced a healthy 305rwhp on 13psi on its initial tune, its heading back to the Dyno in Monday the 15th of Feb for a final tune. hoping for over 320rwhp, Can provide documents. I ran it down the strip once when I first got it, back with the old NICS RB20 and managed a PB of 14.5. Hasn't been back (or anywhere really) with the new setup. Engine has just been fully serviced with Penrite 15w50 Semi-synth, new filters, new coolant & new plugs. Its been done 3 times since I have had the new engine in.
Currently has a ECUTalk consult display installed, latest version, will only part with this for an extra $250. Think thats everything, please feel free to CALL for more info.
TEXT MESSAGES WILL BE IGNORED, DONT PUT 25c INTO MR TELCO'S POCKET FOR NOTHING!!!
Pics:
PS: Standard strut brace included, just doesnt clear engine cross over pipe (by about 2 mm), and plese excuse the red silicon joiner, it was temporary, is now gone.
https://www.sau.com.au/forums/topic/307263-wa-fs-hr31-gts-x/
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
