  • Replies 171
Scathing..its off Parramatta road, and there is an exit along M4 also. once you get in there there is signs everywhere on which parking block you want to go to.
P6 is an open field, no point bringing a shammy if it is raining..lol.
Hey Mate - Just wondering if your guys can maybe do the same for the V36 ???
Hi Kumul
Sorry at this stage we are only able to do series 1 V35 & M35 (2001 - early 2004). We are working on series 2 now (2004 - 2007) and this should be completed by mid this year. The next version after that will be the V36 so I hope we will see it this year.
As I get definate information I will paste it in the forum.
Cheers
Andy
hay, what are we actually doing that day??
havent you watched the carpark scene in Tokyo drift??!!...lol, its just a meet up, putting a face to the people you talk to on the forums and general discussions of each others rides,
Can the organiser edit first post reflecting meeting point/location and time etc.
I tried but there was no option to edit the original post, if anyone knows how to do it, please let me know!
I though P6 was a covered Carpark, i think it makes sence to find a covered carpark even if it coss a couple of dollers. No one is gonna stand around in the rain...are there any covered carparks in olympic park you know of?
<<<<UPDATE>>>>>
Ok guys, a couple of things have changed so here is whats happening till now.
Date: 5th March 2010, Meeting at 7pm..at olympic park.
Location: OLYMPIC PARK(meeting place) then a very short drive down to P6 Carpark in HOMEBUSH.
Invited?: V35's, scathings group of Zeds and a lone M35 :-)
Question : Is any one of the people coming a good photographer?. If so PLEASE bring your camera so we can have a mini shoot for/with the group. Ill be bringing mine, but i'm VERY average.
So far:
  1. sethaiyaar
  2. ripstah
  3. mjay
  4. ezy03
  5. bosco
  6. BLISTC
  7. danny_tg
  8. 08r3308
  9. Yi-Town
  10. ogz007
  11. V35 Matt
  12. justinfox
  13. will's35
  14. timmy
  15. RUS027
  16. g33k
  17. steveyc
  18. andy65b
  19. arnie 350gt
Plus scathings group of Zeds, projected number is around 8-12 cars.
Great meet.
I am in, I will bring my 50% completed DRAFT QUAD HID project with me.
Thanks
Frank
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
