  • Replies 171
posted a few more pics into the gallery i mentioned earlier. nothing too special, but more on the way soon.
I think they're pretty special - those photos make my Engine bay look clean =P
Thanks for upping mine - i've been checking here every 15 minutes for photos hahahaha
I think i'll put your front one as my CarPC background Messiah =)
    • Yes, an R34 workshop manual is downloadable. The R32 GTR one which is findable everywhere would also do the job, seeing as almost all those bolts are same-same enough.
    • It can be hit and miss, I can fit 15mm ones on the v37, but only because the wheel happens to have voids on the mounting face that allow it to fit. Have you checked the mounting face of the wheel and know it will not sit flush? Rather than cut (or try and find shorter) studs, just buy a thicker spacer (unless clearance from the wheel to the guard does not allow it), then everything is reversible in future
    • Obviously you need shorter studs (don't just cut the original studs off!) and really short nuts that will fit in the spacer. Thus exposing the problems with thinner bolt on spacers.
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
