Hey guys i have some parts i dont need anymore so up for sale they go.
ITEM: Nismo 550cc Injectors suit RB25. RRP $1000+
INFO: I had these on my R33 gtst with RB30 bottom end RB25 head making 326rwkw on 20psi. Yellow Tops
They are in excellent condition and GENUINE NISMO product.
http://www.tweakit.net/shop/product_info.p...roducts_id=1124
http://www.injectorsonline.com/indivprod.p...=74&scid=13
PRICE: $500 which is bloody cheap!
ITEM: Cusco R33 GTST OS 232 541A Strut Brace.
INFO: I no longer need it as my RB25/30 now sits higher and i cannot get the brace back on RRP $300+
The CUSCO Strut Bar - Type OS Rear Nissan is a lightweight aluminium shaft with oval section and easy bolt-on with substantial handling improvement. This Cusco Strut Bar Will Increase rigidity and handling performance while adding to the sporty looks of your ride with one of the cheapest and most basic of handling upgrades available.
PRICE: $100 ono
ITEM: R33 GTST Intecooler kit RRP $350+
INFO: I had this kit on when i made the 326rwkw. It has all cooler pipes and intecooler and silicone hoses which fit directly for stock low mount position turbos.
PRICE: $100 ono
I can get pictures of the injectors and cooler kit just let me know i only have a pic of the strut brace.
PICKUP IN SYDNEY preferred but can post anywhere in Australia if need be.
Contact me on 0404 922 525
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
