think he wants to know if the line requires a restricter in it, the answer is no, the restricter should be in the bearing cartridge of a bb turbo
your post. makes sense it does not
should try writing in an explaination
instead of short lines
might help explain what your after?
https://www.sau.com.au/forums/topic/307307-turbo/#findComment-5077735
i thought he was asking if the turbo is supposed to have a bearing inside.. and about a knuckle? assuming it was either the oil or water lines.. but unless he's looking at something else if its already hooked up.. good to know you interpret that
https://www.sau.com.au/forums/topic/307307-turbo/#findComment-5078571
