sounds like fun.. Ill turn up to say hi and look at all the big numbers, Been wanting to head to unigroup to talk to bout getting some work done when the car is getting turbo'd in a few months..
Running my N/A would just be silly although im keen to see what kinda power its running haha.
  • Replies 108
Posted Images
Mark... I'm tempted to f**k with the tune, ramp it up to 20PSi... Only issue being, at 14PSi it already starts to valve float at 6500RPM...
It is tempting to do a self "guess" tune and see if she holds... Come home and do new things... LOL
Let's see who gets the rb30 win :D
Normally we draw up a board for best power for every different engine type, but that's a bit much.
Categories are still being decided, but I think it's going to be something like this:
Best GTR Engine
Best GTS-t/GTT/GT+t Engine
Best GT Engine
Best RB30 Engine
Best Z/V Series Engine
Best Other Engine
That covers pretty much everything but still makes it nice and competative! :banana:
Other time's we've had too many catogories and it just wans't competative enough, it was too spread out. It covers engine swaps too :(
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
