It's ok Liz im happy to provide my own results.
218.5rwkw from a totally stock L76 6.2L GM with 3,700km on the clock im very happy with that. Time to add an OTRCAI, Exhaust and Tune and bump that to about 270rwkw.
  • Replies 108
Posted Images
What about the TT's we were talking about? Oh yeah, then take the whole drivetrain out and transfer into the HiAce!
Courier skids, FTW!!! :D
had a good time tonight guys, good to meet some of you.
im in love with N1GTR Steve's car. couldnt believe it only revved to 6000rpm, what a nugget, and only made 400RWKW at that 6000rpm,, pfffftt.
my GTR made a whopping 235.7RWKW on 14psi, what an absolute power house. time for some boost and a power fc.
Good to meet you finally!!!
Yeah what a shitbox hahaha
"Keep it standard" ;) Or go all out on it, again :)
You'll have to come for a drive when yavuz is finished with it. You'll be trying to buy the setup off me straight away hahaha. It's getting big brakes aswel which is definatly needed
will whip straight around to 8000 once the magnetic interference issue with the crank-angle trigger is sorted
but it was out of safe injector duty-cycle at 'only' 400rwkW anyway (with 1000cc's). E85's awesome, but my God you need enormous amounts of the stuff
next stop 1600cc injectors, more boost, adjust cam lobe-centers and 450+ rear wheel killerwatts should result
Injectors are sorted already. Bosch Indy Blue 1600cc's. Also this revs to 9500rpm no probs, but 3500rpm to 9000rpm is enough of a powerband.
Interesting talking with some people (up the street) on Saturday night about how much E85 is needed vs pump98. All those guys who say 20/30% are wrong, its more like 40/45%. Example; 1000cc's are good for approx 1000hp/745kw at the motor, on E85 mine were all over at 400rwkw which is safe to say at least 450kw/600hp at the motor, which makes it a 40% difference.
That may sound like a small difference (20% between talked about figures and actual results from my car), but for anyone reading i can tell you, its a fkn huge difference when you're on the rollers, there's heaps more ignition advance to run, more boost, dialing in cams etc and the injectors are at 100% duty. Got frustrating?
I have a feeling Bosch Indy Blue 1600's are going to be all sold out very soon, and those Injector Dynamics 2000cc's will be the new "E85 injector of choice"
"Keep it standard" :laugh: Or go all out on it, again :)
WOT it definately can use up to 40% more than pump98, but if you average out with normal driving it works out to be bout 25% more only - maybee they were quoting the average?
I give it to my car but also use it for normal city driving and it gets me 300km a tank, where pump98 gets me 400km
Good point maybe they were quoting the average
average fuel Econ isn't a concern at all of mine though cause it's not daily driven :)
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
