Lots Of Stuff! R32 Gts-t And Gtr, R33 R34, S13...
Hi Everyone,
Just arrived back for 2 months (holidays between uni semesters over there).
Filled my hand luggage and suitcase full of goodies. I dont need any more fans, kimonos or wasabi, so car parts it is!...
Also a few items left over from my own past cars/projects that were still at home. EVERYTHING can be picked up and im happy to help install if you are in the area. KYOGLE (northern NSW near Lismore)
For any car:
Z32 AFM $180 posted. From my old 97 model Zed.
Single DINN slot drawer with fake wood grain front $20
Single DINN triple gauges from R32 and R33 GTRs can be wired in to other cars. $20 to $150
OMORI water temp gauge, 45mm with sensor, mounting etc. $75
R32 GTR:
Triple gauge clusters (crappy $20, perfect $100) have a bunch
CUSCO adjustable castor rods $200 (these will NOT fit 2 wheel drive skylines) GTR and GTS-4 only.
Front indicators $180 a pair, have a 2 spare drivers side ones($80ea) and 2 pairs.
RAZO shift knob $20
R32 GTS-t
Front indicators - 3 clear ones $75 ea
Front indicators - 7 orange ones $60 ea
Z32 AFM with HKS filter, TRUST pipe and wires removed from RB20DET R32. $300
R33
NISMO clear side indicators $75
GTR Triple gauge clusters (carbon face surround type) $100ea and $140 for the red LED one.
Indicators that may be from a different car? (clear) $75 the pair, they were on an aftermarket front bar.
R34
GTT triple guage clusters with wire loom connector. one with cover and would suit project/custom install on another car. $90 and $150 respectively.
S13 stuff:
Aftermarket tail lights $200
Type X tail lights $350
HKS BOV with pipe to fit SR20 $150
S14 stuff:
S1 front indicators $35 ea
CUSCO adjustable castor rods with air deflector $200
Instrument cluster (white face gauges) $100
M's AFR $25 (air flow resetter?)
Front grill (bit between the headlights) $50
TRUST air filter to fit stock airbox $30
Orange indicator (L) $35
I can email high rez photos of any item (bit much to post it all here ><).
Most the bits unpacked
the car these came from:
the drawer
OMORI gauge
R33 gauges
R32 $60 for this one (bit faded)
My home Phone number is: (02)66333131
Email [email protected]
or PM/post here is fine i will check daily.
thanks for looking,
martin
Edited by mmarschall
Bump, S13 type x set sold and posted. Still have a couple more lights and a scratched center (would need a respray).
Our house is now on the market so the more things i can sell the less i have to pack into moving boxes... make an offer! :P
thanks for looking,
martin
Hi Pete, all parts are used.
and 180sx tail light pics:
Both lights come with bulbs and wire/connectors but only one fitted on the pic.
good condition, ill try and clean/polish it over the weekend if i have time. no cracks! Black center garnish has some scratches.
Where i put the blue arrows is a crack in the surface on one lens.
One type X set and the carbon type ones i brought back on my last trip, im sure i have another different aftermarket set somewhere in the packing boxes... (we were planning to sell the house before i went to japan 5 months ago so i already packed half of this car stuff away ><), everything's finally going ahead now....!
with the r32 gtr cluster gauges i want to buy really cheap ones like really cheap i dont care if they dont work i just want it to look clean i want to put it in my r32 gts ive got these graphic equalizer at the bottom which i dont use and i dont how much their worth their clarion ones would anyone know how much their worth ?. i would like to have triple cluster gauges their to give the inside a nice look
Panel filter:
CUSCO S14 rods, printed on them is: CUSCO 232 473 A
Thread, bolts and rubber all perfect.
R32 dinn triple gauges, cheap ones all sold, only near perfect units left (I will try find some more cheapies when im back in Japan). :P
Thanks for looking,
martin
  • 3 weeks later...
Z32 AFM + HKS pod filter + connector/plug with wires, price drop $225 posted
GTR32 drivers side indicators $85 posted. (perfect condition with bulb and connector plug)
Open to offers on whats left and very negotiable for pickup. Im here for another 2 weeks (then back to teaching in Japan).
  • 4 weeks later...
  • 1 month later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
