  dan_the_man said:
I changed it because it was stupid and misleading.
Well "stupid" is your point of view and if you found it "misleading", you only have your self to blame my son.
Maybe I should of put "Threatened with a yellow sticker on the weekend" that would have been more accurate.
Cops are just doing there job and I respect that. There job is a very difficult one that's for sure these days.
But there is no need to throw it in your face "I can yellow you for that" every time you get pulled over just to intimidate you.
No matter how big or small the threat is, a threat is a threat.
So because you "think" the title is "stupid" I see no reason for you to change it to "I was given a warning".
The warning is not what this thread is about.
Love from Ken :)
  • Replies 52
Love from Ken :(
oh yay. Lets argue over it
  Shell said:
:) yeah Dan... why did you change it?? now my comment makes no sense!! :(
for that exact reason shell.
lets get off topic some more. or is talking about the topic considered to be on topic?
topical
topic fixed.
tops
Continue to stick up for yourself Ken, you're a good bloke and you know better than to leave something unfinished in such a way that it could legitimately be yellowed.
If you DO get into a spot of bother and actually get yellowed, try and see Graham Parks at Osborne Park inspection centre, great guy.
-Chris
-Chris
Thanks Chris I'm sure I will be seeing Graham lol.... :)
  Dsturbd said:
I reckon next time they threaten you do this , Piss your pants and yell " im scared leave me alone " . Cops will freak n bust out of there double time :)
Haha unfortunately Brenden I have already tried this and it has failed (they called for backup) :(
LOL @ the F-BOMB.....
Edited by KEN-R34
LOL atleast they didnt Tazer you :)
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
