^^ +1
It's funny how ppl start to worry when the oil temps rise above 90 degrees C on a hot day, when it is considered normal.
Hot outside temps + A/C running (drains a little bit of power, so you put your foot down more) + if you drive hard / on boost = Temps will rise a little higher.
Just make sure you keep your oil and radiator levels topped up and you'll be fine.
https://www.sau.com.au/forums/topic/307354-32-gtr-oil-temp/#findComment-5077397
  • 2 months later...
mine has been most noticeable hot at a little less than 100 degrees, during travel at 100kmh and over 30 minutes.
about the Oil Temp Meter. I know it starts at 70 and finishes at 150. so does what make it 70 90 110 130 150 at each bar. Are these the numbers?
also when it got at this stage the HICAS warning light came on. whats that mean?
please bare with me: whats the oil temp for?
https://www.sau.com.au/forums/topic/307354-32-gtr-oil-temp/#findComment-5215213
GTRs come standard with an oil cooler...
They dont and even NURs dont come with oil cooler. Only N1s come with them.
Mine is always sitting at the bottom of the gauge (75?) when driving around and hottest is around 90+ I think during the SAU drag day which was in the midst of summer! Only did 4 runs though...
https://www.sau.com.au/forums/topic/307354-32-gtr-oil-temp/#findComment-5236129
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
