seems like most r32 gtrs have that dash bubble on the passesnger side
the one im looking at has it too, although its not that badd, i would like to get it fixed in the future if i end up buying it
can it be fixed?
does the dash have to come out?
are there mobile guys that can come around to your place and fix it?
any more info on this would be good, thanks fellas !
https://www.sau.com.au/forums/topic/307360-r32-gtr-dash-bubble/
remove dash...drill a small hole through to bubble from rear...be careful to not put a hole in dash exterior...fill large syringe with upholstery adhesive...inject bubble with adhesive until full...work adhesive back out hole while wet...leave for 5 mins...work bubble from edges to centre to stick back down.
easy!
yeah the method dirtgarage described is the only way I've seen it successfully repaired short of just replacing the whole thing (you can still buy new ones from nissan). it takes a bit of care but if done right it works in most cases. make sure you do have a hole in the back as otherwise when you work the bubble down the excess will come out onto the top surface which you don't want.
i wonder if this technique would work from from the front? make a small hole in the bubble, fill with glue and work it until its fixed. of coarse your gona hav a small mark where the hole is but atleast the bubble would be gone !! hmm
easy!
  • 2 months later...
ok i dropped the glove box down today, made a hole directly behind where the bubble is, filler it up with contact cement, worked it etc etc...
result ? looks worse then when i started ! didnt sem to stick evenly and the middle part is sticking up like a ballon...seriosuly looks like ass
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
