seems like most r32 gtrs have that dash bubble on the passesnger side
the one im looking at has it too, although its not that badd, i would like to get it fixed in the future if i end up buying it
can it be fixed?
does the dash have to come out?
are there mobile guys that can come around to your place and fix it?
any more info on this would be good, thanks fellas !
https://www.sau.com.au/forums/topic/307360-r32-gtr-dash-bubble/
remove dash...drill a small hole through to bubble from rear...be careful to not put a hole in dash exterior...fill large syringe with upholstery adhesive...inject bubble with adhesive until full...work adhesive back out hole while wet...leave for 5 mins...work bubble from edges to centre to stick back down.
easy!
yeah the method dirtgarage described is the only way I've seen it successfully repaired short of just replacing the whole thing (you can still buy new ones from nissan). it takes a bit of care but if done right it works in most cases. make sure you do have a hole in the back as otherwise when you work the bubble down the excess will come out onto the top surface which you don't want.
i wonder if this technique would work from from the front? make a small hole in the bubble, fill with glue and work it until its fixed. of coarse your gona hav a small mark where the hole is but atleast the bubble would be gone !! hmm
easy!
  • 2 months later...
ok i dropped the glove box down today, made a hole directly behind where the bubble is, filler it up with contact cement, worked it etc etc...
result ? looks worse then when i started ! didnt sem to stick evenly and the middle part is sticking up like a ballon...seriosuly looks like ass
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
