Am getting a Haltech MAP sensor based ECU installed & tuned on my RB25 R32 & need an air temp sensor.
Have been told I can use an RB26 item.
I thought these were incorporated in the AFM but am hoping now that I was wrong.
Was also told I could use a Delco item which is something I assume could be bought from automotive parts stores but surely they sell more then one type...
Has anyone used a MAP sensor based ECU & had to source an air temp sensor & if so what did you get & where from?
Cheers,
Brett
the GTR air temp sensor is the same part # as the water temp sensor that the ECU uses
so find the part # for that and away you go
be sure to note there are two water temp sensors
one will be the for the ECU (this is the one you want)
and the other is the dash gauge
drop past meridian, they usually have a good assortment of Delco and bosh AIT's.
If not osaka or type m should have a few about the place. I just checked and dont have any laying around.
There probably are, but i havent investigated. If you have a look at an aftermarket sensor, it is a small diode or a piece of nicronium wire, which is sensitive and reacts quickly. The nissan one reacts very slowly, which is fine for what it does with the stock ecu, but its role is far more important with a map sensored ecu.
Ok, I am about to put in an EMS Stinger 4424 into my RB20 R32 and was not aware that I'd need an air temp sensor... can someone point me in the right direction to sus out what I need to do please?
Thanks in advance
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
