aussy-boyz Posted February 8, 2010 Share Posted February 8, 2010 rb20det silvia, any one no how to get temp guage working on dash??? any help would be great cheers Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/ Share on other sites More sharing options...
JonnoHR31 Posted February 8, 2010 Share Posted February 8, 2010 you need the original silvia gauge sender or another from the same model silvia. gauge senders are car specific, not motor specific Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5077795 Share on other sites More sharing options...
aussy-boyz Posted February 8, 2010 Author Share Posted February 8, 2010 sender off sr20???? then do you no how i wire it up????? Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5077871 Share on other sites More sharing options...
JonnoHR31 Posted February 8, 2010 Share Posted February 8, 2010 sender should plug (or rather slide) into the 20 loom. then at the ecu end you need to find the temp gauge wire on the ecu side of the 20 body loom plug then wire it up to the temp gauge wire on your standard silvia body loom Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5077933 Share on other sites More sharing options...
aussy-boyz Posted February 8, 2010 Author Share Posted February 8, 2010 sender should plug (or rather slide) into the 20 loom. then at the ecu end you need to find the temp gauge wire on the ecu side of the 20 body loom plug then wire it up to the temp gauge wire on your standard silvia body loom ah yeah sound easy will just find the r32 wiring diagram Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5077975 Share on other sites More sharing options...
Simon-S14 Posted February 8, 2010 Share Posted February 8, 2010 large 18 pin plug i think, Black with blue wire. thats the temp sender, and as mentioned needs to match the original engine that was in car so either ca or sr. wire it up to the white plug on the s13 body loo0m, also black/blue. Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5078098 Share on other sites More sharing options...
Dose Pipe Sutututu Posted February 8, 2010 Share Posted February 8, 2010 look at my signature, download the pdf Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5078229 Share on other sites More sharing options...
aussy-boyz Posted February 13, 2010 Author Share Posted February 13, 2010 its not workin. bit confused there is a 2 wire plug at rear of motor with blue with black stripe so tried that after changing temp sensor, wired from that wire into s13 cabin blue with black stripe not workin. found another blue with black srtipe wire on the rb20det cabin wiring wired that to s13 blue with black stripe still no good, any ideas??? cheers Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5086177 Share on other sites More sharing options...
grigor Posted February 13, 2010 Share Posted February 13, 2010 Presume you've used the Rb20 engine harness so you'll have some plugs at the ecu which would normally connect to the R32 dash harness. Find this plug (attached) and connect to the S13 dash temp. gauge wire, after you've swapped the Rb temp sensor. I suggest you use John's excellent instructions, we've all been there. Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5086205 Share on other sites More sharing options...
aussy-boyz Posted February 13, 2010 Author Share Posted February 13, 2010 yeah man iv done that took that temp sensor wire off that rb one and put it onto the s13 cabin blue/black Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5086230 Share on other sites More sharing options...
aussy-boyz Posted February 13, 2010 Author Share Posted February 13, 2010 can u use a wire of the ecu???????? Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5086261 Share on other sites More sharing options...
aussy-boyz Posted February 14, 2010 Author Share Posted February 14, 2010 no ideas??? theres a plug behind the plenum thats not pluged to anything with a blue/black wire and a green wire is that supose to be pluged into something for it to work Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5086765 Share on other sites More sharing options...
STATUS Posted February 14, 2010 Share Posted February 14, 2010 can u use a wire of the ecu???????? No as there are two water temp sensors, one for the ecu (wont give correct output for dash) and the second sensor is purely for the dash. You sound out of your depth take it somewhere. Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5086793 Share on other sites More sharing options...
aussy-boyz Posted February 14, 2010 Author Share Posted February 14, 2010 No as there are two water temp sensors, one for the ecu (wont give correct output for dash) and the second sensor is purely for the dash. You sound out of your depth take it somewhere. lol nah man im a mechaic. What iv done it should work but its not maybe the guage is stuffed Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5086855 Share on other sites More sharing options...
Wheezy Posted February 14, 2010 Share Posted February 14, 2010 lol nah man im a mechaic. What iv done it should work but its not maybe the guage is stuffed Did the gauge work before the conversion? and how does being a mechanic automatically make you an auto elec? Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5087015 Share on other sites More sharing options...
aussy-boyz Posted February 14, 2010 Author Share Posted February 14, 2010 dunno man bought the silvia with a blown sr never really drove it. then chucked the rb in. yeah i agree man im not a wizz on skylines and there motors i dont no what every wire on the motor does. iv dont the whole conversion my self and everything works except gauge Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5087129 Share on other sites More sharing options...
Wheezy Posted February 15, 2010 Share Posted February 15, 2010 Can you get the gauge to move, using a multi metre? That is what I did when putting R32 engines into R31's That will tell you if it works at all. Perhaps you need a resister? Sometimes Tacho's need that done to get them working when changing engines. Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5088312 Share on other sites More sharing options...
Simon-S14 Posted February 15, 2010 Share Posted February 15, 2010 lol mechanic hey... anyway test the gauge by earthing the blue black wire out on the chassis loom near the ecu. if the gauge moves all the way to H and beyond then it works and its the right wire. THEN use a multimeter and test the continuity between the plug on the single pin temp sender, and on of the blue/black wires in plugs opn the engine loom near the ECU plug. once you find the correct wire (the one with continuity) then solder it to the dash wire and it should work. if it still doesnt work then your temp sender is the wrong one or faulty Link to comment https://www.sau.com.au/forums/topic/307400-rb20det-silvia-any-one-no-how-to-get-temp-guage-working-on-dash/#findComment-5088459 Share on other sites More sharing options...
