sender should plug (or rather slide) into the 20 loom. then at the ecu end you need to find the temp gauge wire on the ecu side of the 20 body loom plug then wire it up to the temp gauge wire on your standard silvia body loom
ah yeah sound easy will just find the r32 wiring diagram
large 18 pin plug i think, Black with blue wire. thats the temp sender, and as mentioned needs to match the original engine that was in car so either ca or sr. wire it up to the white plug on the s13 body loo0m, also black/blue.
its not workin. bit confused there is a 2 wire plug at rear of motor with blue with black stripe so tried that after changing temp sensor, wired from that wire into s13 cabin blue with black stripe not workin. found another blue with black srtipe wire on the rb20det cabin wiring wired that to s13 blue with black stripe still no good, any ideas???
cheers
Presume you've used the Rb20 engine harness so you'll have some plugs at the ecu which would normally connect to the R32 dash harness.
Find this plug (attached) and connect to the S13 dash temp. gauge wire, after you've swapped the Rb temp sensor.
I suggest you use John's excellent instructions, we've all been there.
can u use a wire of the ecu????????
No as there are two water temp sensors, one for the ecu (wont give correct output for dash) and the second sensor is purely for the dash. You sound out of your depth take it somewhere.
lol nah man im a mechaic. What iv done it should work but its not maybe the guage is stuffed
Did the gauge work before the conversion? and how does being a mechanic automatically make you an auto elec? :)
dunno man bought the silvia with a blown sr never really drove it. then chucked the rb in. yeah i agree man im not a wizz on skylines and there motors i dont no what every wire on the motor does. iv dont the whole conversion my self and everything works except gauge
Can you get the gauge to move, using a multi metre? That is what I did when putting R32 engines into R31's :down:
That will tell you if it works at all. Perhaps you need a resister? Sometimes Tacho's need that done to get them working when changing engines.
lol mechanic hey...
anyway test the gauge by earthing the blue black wire out on the chassis loom near the ecu. if the gauge moves all the way to H and beyond then it works and its the right wire.
THEN use a multimeter and test the continuity between the plug on the single pin temp sender, and on of the blue/black wires in plugs opn the engine loom near the ECU plug. once you find the correct wire (the one with continuity) then solder it to the dash wire and it should work. if it still doesnt work then your temp sender is the wrong one or faulty
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
