Have a bit of a question re compliance, is it illegal for the company doing the compliance to comply a car which has had an integral part of the car removed? say the abs module? Is it also illegal for said company to then pass the car as roadworthy? This would of been done a few years ago, under sevs.
https://www.sau.com.au/forums/topic/307406-compliancing-question/
The short answer is if it's not roadworthy and is passed as roadworthy, then yes that would be considered illegal, but also bear in mind that once the car has been driven away from the workshop, they can claim that you or someone else pulled it out. If the ABS light isn't on, there's a chance they may have simply overlooked it - I've seen a couple of cars come out of Japan with the ABS disconnected.
yeah pretty tough to go back a 'few years ago' and prove what was/was not on the car. I'm not sure having ABS removed makes a car un-roadworthy. particularly if it was say an R32 skyline which has variants that come with ABS and other variants that have no ABS. It's a bit of a foggy question. In short, I'd say yes it's illegal. But if you have plans of suing them, or getting some kind of compensation from them then I'd say the chances are slim. They will almost certainly argue that the car was complied with ABS installed and fully functioning and that someone else has removed it in the intervening years.
if you only just found out about it what makes you think the compliancer or importer knew about it? especially if its just the abs module, none of the big engine bay gear. Dont go pointing fingers just yet, roadworthy doesnt check for abs working, just a simple brake test, and theres no way that any agent in japan should be expected to make sure the abs in every car they purchase functions correctly, in fact that would be near impossible.
I had known it had been removed, I just didn't know it could possibly cause me issues.
And Yeah well considering the plugs for the abs were tucked into the guard, and there was heat wrap around the lines I think not. Pretty bloody obvious.
That including the fact the roadworthy passed the car with bald front tires, and the fact I needed to get all 4 rotors replaced two days later as the pads were worn down to the metal/bonding material (like they did that in a 300km roadtrip home.....) makes me think they took their time doing the roadworthy.....
Amongst other things, I later found out the car had 60000kms taken off of it from when it was for sale in japan. Now who exactly wound it back I don't know, but I wasn't really suprised when I found out either.
I highly doubt anything will come of this, just utterly pissed off with the dealer I bought the car off.
as far as the insurance implications go I would ring and anonymously ask your insurance company how they see it. maybe it can be noted on the policy that the car doesn't have ABS or some such. not having ABS wont necessarily instantly make it un-roadworthy. it does sound like the company that sold it to you may have glossed over a few things though :) bit of a shame.
Doubtful the person on the phone would know how the law would treat this.
Now that you know about it, some policies state that if it is a known defect that contributes to the loss, you could be for some of that loss. Which company are you with?
Sounds like shenannigans going on between the dealership & the roadworthy.
Sounds like you're not the 1st
Sounds like they'll do it to others
Sounds like...
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
