Have a bit of a question re compliance, is it illegal for the company doing the compliance to comply a car which has had an integral part of the car removed? say the abs module? Is it also illegal for said company to then pass the car as roadworthy? This would of been done a few years ago, under sevs.
https://www.sau.com.au/forums/topic/307406-compliancing-question/
The short answer is if it's not roadworthy and is passed as roadworthy, then yes that would be considered illegal, but also bear in mind that once the car has been driven away from the workshop, they can claim that you or someone else pulled it out. If the ABS light isn't on, there's a chance they may have simply overlooked it - I've seen a couple of cars come out of Japan with the ABS disconnected.
yeah pretty tough to go back a 'few years ago' and prove what was/was not on the car. I'm not sure having ABS removed makes a car un-roadworthy. particularly if it was say an R32 skyline which has variants that come with ABS and other variants that have no ABS. It's a bit of a foggy question. In short, I'd say yes it's illegal. But if you have plans of suing them, or getting some kind of compensation from them then I'd say the chances are slim. They will almost certainly argue that the car was complied with ABS installed and fully functioning and that someone else has removed it in the intervening years.
if you only just found out about it what makes you think the compliancer or importer knew about it? especially if its just the abs module, none of the big engine bay gear. Dont go pointing fingers just yet, roadworthy doesnt check for abs working, just a simple brake test, and theres no way that any agent in japan should be expected to make sure the abs in every car they purchase functions correctly, in fact that would be near impossible.
I had known it had been removed, I just didn't know it could possibly cause me issues.
And Yeah well considering the plugs for the abs were tucked into the guard, and there was heat wrap around the lines I think not. Pretty bloody obvious.
That including the fact the roadworthy passed the car with bald front tires, and the fact I needed to get all 4 rotors replaced two days later as the pads were worn down to the metal/bonding material (like they did that in a 300km roadtrip home.....) makes me think they took their time doing the roadworthy.....
Amongst other things, I later found out the car had 60000kms taken off of it from when it was for sale in japan. Now who exactly wound it back I don't know, but I wasn't really suprised when I found out either.
I highly doubt anything will come of this, just utterly pissed off with the dealer I bought the car off.
as far as the insurance implications go I would ring and anonymously ask your insurance company how they see it. maybe it can be noted on the policy that the car doesn't have ABS or some such. not having ABS wont necessarily instantly make it un-roadworthy. it does sound like the company that sold it to you may have glossed over a few things though :) bit of a shame.
Doubtful the person on the phone would know how the law would treat this.
Now that you know about it, some policies state that if it is a known defect that contributes to the loss, you could be for some of that loss. Which company are you with?
Sounds like shenannigans going on between the dealership & the roadworthy.
Sounds like you're not the 1st
Sounds like they'll do it to others
Sounds like...
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
