if anyone in adelaide can help i need a section off the front left skirt and can come chop off myself??
Hi man
If you can't get in adelaide i can help but i am in tassy but i don't mind sending if you let me know what you may need
stuart 0409135950
michaeljonh23 maybe has what you have to check on damage ask him
hahaha
ooops wrong section lol........
yeah mate got what your after.......text me on 0402613042
