  • Replies 63
As for thread top secret ftw (i also have a full top secret kit)
as for vertex/bn style kits i cant stand the front / rear of them.. i'm not sure why but dare i say it.. veilside rear bar looks better then the fugly square things that stick out a mile in real life.. imo
in saying that though id still prefer the vertex style over the veilside front and sides (i actually really like the side skirts of the vertex style)
dont wana start a shit fight here but how on earth could u pick on BN rear bar when ur rear bar looks like its got a little foot well step in the side incase you want to climb on the boot (refer to ur sig photo for an example).
I completely agree with you, its the thing i hate most about my car.
I was just saying i also dont like the BN looks a bit funny in my eyes (also the front looks like it needs to push some snow somewhere or something). The 400R rear bar looks nice and simple and blends in nicely with most side skirts imo
also my rear bar is actually just pods and yes pods are fugly unless there the stock ones lol.
http://img360.imageshack.us/img360/8348/f275ab37sg1.jpg
Top Secret +1! i gotta agree with ya about the veilside REAR bar
i do like it because of the curves it gave my car. anything else of veilside is pretty damn :down:
mind the wheels :ermm: made the noob mistake of ordering the wrong offset :down:
the kit im after is a mixture with a trust style front bar and jun sideskirts and rear bar i think this will look like porn
or it'll look like three different styles from three different kits on one car.
its a bit hit and miss, make sure the angles and the lines match up and flow from one to another.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
