hi
im selling my do-luck bodykit fits a s1 gts i brought a year ago and neva had time to get around to get it on the car, and now im sellin it due to the car it was going on got in a crash and is unfix able so now takin up room around the house and just need the cash aswell.
items include:1 front bar, 1 rear bar, 2 side skirts
price: $1100 ono
postage: pik up onli
https://www.sau.com.au/forums/topic/307438-r33-gts-s1-do-luck-bodykit-forsale/
hi
price: $1100 ono
