Ok Ive been looking at getting my car the big dyno tune my sochi in NZ at st hitech...hes a good tuner and well known, so he should be able to give me a good tune,
So iv got so far in my s2 rb25det
FMIC,
3" straight through exhaust,
Some cheap unknown fuel pressure reg.
external wastegate,
and a dsr430 turbo with standard manifold,
Greddy profec b spec 2
And the following i havent put in yet
my power fc, hi flowed 650cc injectors, z32afm
And i was wondering wether to go with a bosch fuel pump or a nismo one i know a mate whos selling that came off a gtr running two of them with 650 atw...aparently there better then walbro and bosch but i dont know...? so was thinking go for the bosch.
But onto the main point! i was wondering if a should get any adjustable cams...iv seen on the net that people get some good gains out of them....iv seen tomei cams suggested as a good upgrade but they are quite expensive but are good quality, but what about cheap no name cams? like http://www.trademe.co.nz/Trade-Me-Motors/C...n-270396498.htm or are they a big no no? theres plenty of them around
And what sort of power can i get out of new cams with this kind of set up? is it even worth it?
Thanks guys really appreciate it!
Edited by R33 0wnerrr
https://www.sau.com.au/forums/topic/307479-adjustable-cam-gear-options/
for the fuel pump I would strongly advise you go with a ECR33 nismo one. don't use a GTR nismo one. get the one to suit your car. otherwise it's a waste having a 'bolt on' pump that wont fit your car without modification. the fuel pump is the heart of your car. it pumps the life blood around. without a good one you're doomed. spend the money and buy a NEW nismo pump.
are you talking about cam gears or cams? you keep saying cams but I think you mean cam gears. I would stay away from the cheap ones. they are well known to slip. the best ones are Trust or Tomei. they both have 5 bolts holding them in position. The other option that is very good (if done properly) is a standard cam gear modified to be adjustable. Lots of places do this now and some are really good and still quite cheap.
Yea i was meaning adjustable cam gears sorry!
Is somthing like http://www.nengun.com/tomei/adjustable-cam-pulley any good? would i get any good gains out of having adjustable cam gears? or are they a waste of time without cams to go with it?
Oh and doesnt vct need a controller because installing new cam gears disable it?
thankyou
What are the benefits of having a cam gear? im thinking of getting one, if so i wouldn't need the VTC side? just the exhaust side yeh?
Geraus dont waste your money, for your setup their is not enough benefit.
Don't just tease us with results of more low end/ midrange torque... what did you set it at? and what turbo do you have? was it laggy to begin with and now you've made it more bearable or was it good before and now great? I know it is fairly dependent on the full set up and what works for one engine won't necessarily work for another but the more info available on each persons setup and results the more we all learn.
Cheers
r these any good from access,have you used them?
Cheers
I'm running a gt3076r. The car got all mods done including cam gear but saw the graphs of before and after. It does make a noticable difference. Can't tell you kw differences as I don't have the sheet infront of me but it was worth the money.
So ud recomend i get one? did u get the standard exhaust side cam made adjustable or did u buy aftermarket ones?
Ive just ordered this one for $60 delivered
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWNX:IT
for rb26dett exhaust
my rb25det has one from a sau group buy a few years ago.
for $60 del. you cant go wrong :laugh:
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
