Today i got the call from the head shop and my head is warped to no avail. So the car is up for sale, as is because i cant be bothered.
Everything on the car is stock, and the car is 100% STRAIGHT! interior is VERY CLEAN & UN-MOLESTERED - i've owned the car for 6 years, before that its owner was my brother-in-law, who imported it in 1999/2000. with 30k on the clock.
The car has:
- 4x 6k old Nitrogen filled Maxxis mid-range sport tires.
- Brand new 52mm ALUMINIUM radiator. (more on this later)
- New Timing belt (not installed).
- New head gasket (not installed).
- Nice muffler from japan (not a cannon) - installed)
- Clean interior
- Straight body
- NO CRASHES
- All 4 corners have STOCK suspension which is firm & makes no noises!
- Gearbox is perfect, no syncro wear.
Car had a recent ROADWORTHY because i was thinking of selling before the overheating, car passed perfectly except for FRONT CONTROL ARM BUSHES - which i got changed then and there!
So when a new engine is in (or new head) - (BLOCK IS PERFECT) - then car will easily pass a roadworthy. (ofcourse the new engine will need certification from your mechanic/engineer - but they can do this as part of your RWC.)
Aircon is PERFECT! recently rehauled before summer, ran GREAT as i had it re-conditioned, but had to bleed because i took the engine apart.
STORY;
I was driving home from autobarn and the car overheated, so i pulled over and found the stock radiator top pipe had cracked (plastic) so i reattached pipe, filled with coolant and off i went, everything was fine...
On another local trip, almost home car started overheating again and the radiator top completely broke and i had the car towed home. From there i thought maybe the thermostat wasnt working, sticking, thats why it intermittently overheated, so i removed it and grabbed a new radiator (Aluminum one) & installed this, bled coolant into the system, then went for a drive... the needle only just came off COLD and stayed there no matter what - so water pump was good, radiator was good, but soo large and without a thermostat, ran too cold.
But from there excess pressure built up in the coolant system, and my mechanic and i came to the conclusion the head gasket is gone or the head is cracked/warped - the overheating was due to a sticking thermostat.
So i got down to business, low & behold, the head is warped due to overheating, and causing exhaust gas to enter the coolant system...
So.. after that novel, i require a new head & thermostat and the car is like new again... but after all this i really cant be bothered...
OUTCOME;
I want to sell it AS IS - that is NO RWC and NO REGO.
You come and pick-it up on a trailer and its gone.
I will happily put the engine back together so its easier to transport.
Car will come without a radio.
Car will come WITH the new head gasket, timing belt & new aluminum radiator.
PRICE;
I want $5500 and take it away, a good NA engine is $500 on here, plus the work of changing just the short motor, isnt much for the mechanically minded and a few friends OR just get your trusted mechanic to do it.
Remember the car is STRAIGHT, NO CRASHES, INTERIOR IS VERY TIDY, AND WAS IS IN ROADWORTHY CONDITION (as of 2 weeks ago) BAR THE ENGINE... you are not buying a thrashed lemon, the car was well taken care of and serviced. With a new engine, this car will outlive most NA R33s.
Matt - 0419116318 - Dont hesitate to call.
@MYSTRM
- Hey there, thanks for the offer, but i dont have that much to put on top to get your car.
@green1via
- Sounds pretty good, can you give me more info on the Cefiro? condition, k's, working order?... also do you mean you'll chuck cash my way or you want cash your way?
@MYSTRM
@green1via
No worries, good luck with sale
cheers
Thanks MYSTRM, good luck with finding a nice NA.
@curlyjimbo
- The cost to fix overheating is a new thermostat and a new head.. thats it. everything else i have and will come with the car.
im pretty sure on here you can find a NA head for $150-$400 bucks? so my loss is your gain.
Matty
@curlyjimbo
Matty
Is there something I'm missing?
+ Would it be hard to get a RWC on it since it's not running yet?
In what sense? i just dont have the time to fix it, it'll be worth more to fix and sell, but i dont have the time.
And getting a roadworthy now would be impossible, because it wont start.. you'd have to get a new head OR new engine, then it'll get a RWC really easy.
So if I were to pay for the parts/work needed to be done to get the car in good working order so it could be registered, would you know roughly how much money we're looking at realistically?
and some more pics would be great!
Thanks.
Thanks.
What pics are you interested in? i can take some and post.
And if going the new head route... getting the new head (150-400), having it shaved ($100), new head bolts ($?) then all you gotta do is the new head gasket (supplied), torque head down, reattach exhaust and intake, new timing belt, harmonic balancer, intake piping, replace thermostat, fit radiator, then fill rad, and the car is ready to get its roadworthy
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
