Today i got the call from the head shop and my head is warped to no avail. So the car is up for sale, as is because i cant be bothered.
Everything on the car is stock, and the car is 100% STRAIGHT! interior is VERY CLEAN & UN-MOLESTERED - i've owned the car for 6 years, before that its owner was my brother-in-law, who imported it in 1999/2000. with 30k on the clock.
The car has:
- 4x 6k old Nitrogen filled Maxxis mid-range sport tires.
- Brand new 52mm ALUMINIUM radiator. (more on this later)
- New Timing belt (not installed).
- New head gasket (not installed).
- Nice muffler from japan (not a cannon) - installed)
- Clean interior
- Straight body
- NO CRASHES
- All 4 corners have STOCK suspension which is firm & makes no noises!
- Gearbox is perfect, no syncro wear.
Car had a recent ROADWORTHY because i was thinking of selling before the overheating, car passed perfectly except for FRONT CONTROL ARM BUSHES - which i got changed then and there!
So when a new engine is in (or new head) - (BLOCK IS PERFECT) - then car will easily pass a roadworthy. (ofcourse the new engine will need certification from your mechanic/engineer - but they can do this as part of your RWC.)
Aircon is PERFECT! recently rehauled before summer, ran GREAT as i had it re-conditioned, but had to bleed because i took the engine apart.
STORY;
I was driving home from autobarn and the car overheated, so i pulled over and found the stock radiator top pipe had cracked (plastic) so i reattached pipe, filled with coolant and off i went, everything was fine...
On another local trip, almost home car started overheating again and the radiator top completely broke and i had the car towed home. From there i thought maybe the thermostat wasnt working, sticking, thats why it intermittently overheated, so i removed it and grabbed a new radiator (Aluminum one) & installed this, bled coolant into the system, then went for a drive... the needle only just came off COLD and stayed there no matter what - so water pump was good, radiator was good, but soo large and without a thermostat, ran too cold.
But from there excess pressure built up in the coolant system, and my mechanic and i came to the conclusion the head gasket is gone or the head is cracked/warped - the overheating was due to a sticking thermostat.
So i got down to business, low & behold, the head is warped due to overheating, and causing exhaust gas to enter the coolant system...
So.. after that novel, i require a new head & thermostat and the car is like new again... but after all this i really cant be bothered...
OUTCOME;
I want to sell it AS IS - that is NO RWC and NO REGO.
You come and pick-it up on a trailer and its gone.
I will happily put the engine back together so its easier to transport.
Car will come without a radio.
Car will come WITH the new head gasket, timing belt & new aluminum radiator.
PRICE;
I want $5500 and take it away, a good NA engine is $500 on here, plus the work of changing just the short motor, isnt much for the mechanically minded and a few friends OR just get your trusted mechanic to do it.
Remember the car is STRAIGHT, NO CRASHES, INTERIOR IS VERY TIDY, AND WAS IS IN ROADWORTHY CONDITION (as of 2 weeks ago) BAR THE ENGINE... you are not buying a thrashed lemon, the car was well taken care of and serviced. With a new engine, this car will outlive most NA R33s.
Matt - 0419116318 - Dont hesitate to call.
@MYSTRM
- Hey there, thanks for the offer, but i dont have that much to put on top to get your car.
@green1via
- Sounds pretty good, can you give me more info on the Cefiro? condition, k's, working order?... also do you mean you'll chuck cash my way or you want cash your way?
@MYSTRM
@green1via
No worries, good luck with sale
cheers
Thanks MYSTRM, good luck with finding a nice NA.
@curlyjimbo
- The cost to fix overheating is a new thermostat and a new head.. thats it. everything else i have and will come with the car.
im pretty sure on here you can find a NA head for $150-$400 bucks? so my loss is your gain.
Matty
@curlyjimbo
Matty
Is there something I'm missing?
+ Would it be hard to get a RWC on it since it's not running yet?
In what sense? i just dont have the time to fix it, it'll be worth more to fix and sell, but i dont have the time.
And getting a roadworthy now would be impossible, because it wont start.. you'd have to get a new head OR new engine, then it'll get a RWC really easy.
So if I were to pay for the parts/work needed to be done to get the car in good working order so it could be registered, would you know roughly how much money we're looking at realistically?
and some more pics would be great!
Thanks.
Thanks.
What pics are you interested in? i can take some and post.
And if going the new head route... getting the new head (150-400), having it shaved ($100), new head bolts ($?) then all you gotta do is the new head gasket (supplied), torque head down, reattach exhaust and intake, new timing belt, harmonic balancer, intake piping, replace thermostat, fit radiator, then fill rad, and the car is ready to get its roadworthy
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
