  • Replies 57
Posted Images
Car went into the panel beaters today. Didn't feel confident with them paint matching off a picture so i just went with BT2. However I spotted a Toyota Rukus on the road in 'Voodoo Blue' (colour code 8T6), and to me it looks exactly like Calsonic Blue.
What do you guys think?
cp4796861350678176234.jpg?height=700&aspect=FitWithinNoPad&width=1050scion_xb_08_8T6_03.jpg
The Tru Blu Falcon looks to be the exact colour:
If anyone has any idea how to track this paint code I would really appreciate it. Need to give the sprayer a colour next week. Thanks guys!
Do you know what the name of that paint code is? I found the DJR code and it's Skyish Blue 17539 code AT Ford commercial 85-86. Going to Bathurst this weekend so I'll be able to see it in the flesh
Got another look at the tru blu DJR car and I'm convinced it's the colour I want. If I give the sprayer the right colour code, is it guaranteed to come out the right colour? Never dealt with spray painting a car before so i want to know 100% it will come out right.
mind blown.
Haha... well I have. Not seen any Jap cars in Europe with it... nor any Euro cars in Japan with it. Now you point it out... my bad.... I am a little derailed some times.
OP sorry but what about Porsche Riviera Blue it looks sooo good as a colour in the flesh... (not the best in the pics but awesome and sort of looks midway between the colours from the falken cars which also look uber cool).
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
