  • Replies 73
I will be organising one for some time in June at ESP.
http://www.skylinesaustralia.com/forums/Dy...ay-t304404.html
Your car looks tops, hope we can see you there!
You might want to have a chat to Glen, I have a feeling the Supra boys may have locked in the June date @ ESP......
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5081647
So I take it we cant have both the skylines and the supras on the same day? So we might have to go the 12th?
Thanks Donnan for the compliment on the car btw.
Cheers,
Edited by xanavinismo
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5082041
Hi all
We made our dyno day on the Sunday as I saw you guys/gals were planning on holding yours on the Saturday. We do at this stage only have 10 people intersted but we are 4 months out and numbers could change + or - we just can't tell at this stage.
I very much doubt that we will have 30 Supra's there but there may not be enough spaces for Skyline owners. If we could leave it for a couple of months and I'll have a chat to the committee and the guys at ESP to see if we can change it around a little to have more spots available so we can have both groups there.
I think it would be great to have both groups there for a big dyno day as well but we have to be mindful of our members at this stage and I will get back to you all with any updates.
Happy to discuss.
Cheers
Ross
Edited by RP071
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5082492
I am sure the boys at ESP would like to relax on a sunday and they said to me that they would be free any time in june.
I think it would be great to have both groups there. If we can get between 20-30 cars on the dyno, I reckon it would make for a great day!
But, we will have to see who is actually going to commit to having a working car....
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5082971
I've got to go in before then and get mine tickled up, so I'll be seeing Glen and Dan in the next month or so.
http://www.skylinesaustralia.com/forums/Wm...html&hl=wmi
But I'll see how work etc is and might try to make it over for a dyno day as well........as usual, no promises.
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5095250
Hey everyone, it would seem that our Supra counterparts are well organised for the dyno day!
They have laid down the challenge to see if we can get 10-15 working cars together.
http://www.supraforums.com.au/forum/showthread.php?t=58995
Where:ESP, Gilmore Rd, Queanbeyan
When: Sunday, 06/06/10. First car on the rollers at 9am. so get there early or you might miss out!
How much: Skylines $50, anything else $60
There might even be a sound off, so there will be something for everyone!
The more people there the better, so even if you don't have a car you should still come along to watch and lend some support!
If there is anything people can do to lend a hand, please let me know.
I'll even put myself down on the list:
1- Donnan
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5102448
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
