  • Replies 73
I will be organising one for some time in June at ESP.
http://www.skylinesaustralia.com/forums/Dy...ay-t304404.html
Your car looks tops, hope we can see you there!
You might want to have a chat to Glen, I have a feeling the Supra boys may have locked in the June date @ ESP......
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5081647
So I take it we cant have both the skylines and the supras on the same day? So we might have to go the 12th?
Thanks Donnan for the compliment on the car btw.
Cheers,
Edited by xanavinismo
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5082041
Hi all
We made our dyno day on the Sunday as I saw you guys/gals were planning on holding yours on the Saturday. We do at this stage only have 10 people intersted but we are 4 months out and numbers could change + or - we just can't tell at this stage.
I very much doubt that we will have 30 Supra's there but there may not be enough spaces for Skyline owners. If we could leave it for a couple of months and I'll have a chat to the committee and the guys at ESP to see if we can change it around a little to have more spots available so we can have both groups there.
I think it would be great to have both groups there for a big dyno day as well but we have to be mindful of our members at this stage and I will get back to you all with any updates.
Happy to discuss.
Cheers
Ross
Edited by RP071
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5082492
I am sure the boys at ESP would like to relax on a sunday and they said to me that they would be free any time in june.
I think it would be great to have both groups there. If we can get between 20-30 cars on the dyno, I reckon it would make for a great day!
But, we will have to see who is actually going to commit to having a working car....
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5082971
I've got to go in before then and get mine tickled up, so I'll be seeing Glen and Dan in the next month or so.
http://www.skylinesaustralia.com/forums/Wm...html&hl=wmi
But I'll see how work etc is and might try to make it over for a dyno day as well........as usual, no promises.
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5095250
Hey everyone, it would seem that our Supra counterparts are well organised for the dyno day!
They have laid down the challenge to see if we can get 10-15 working cars together.
http://www.supraforums.com.au/forum/showthread.php?t=58995
Where:ESP, Gilmore Rd, Queanbeyan
When: Sunday, 06/06/10. First car on the rollers at 9am. so get there early or you might miss out!
How much: Skylines $50, anything else $60
There might even be a sound off, so there will be something for everyone!
The more people there the better, so even if you don't have a car you should still come along to watch and lend some support!
If there is anything people can do to lend a hand, please let me know.
I'll even put myself down on the list:
1- Donnan
https://www.sau.com.au/forums/topic/307610-dyno-day/#findComment-5102448
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
