Hi all
Sorry, but the bank account is:
Account Name: ACT Supra Club Inc
BSB: 182-222
Account Number: 122885536
Please let me know if you have any issues or questions.
Cheers
Ross
Ohhh so $50 into this account... also what should we use as reference that we have already paid etc... :D
Cheers,
Glen
Edited by xanavinismo
https://www.sau.com.au/forums/topic/307610-dyno-day/page/4/#findComment-5229337
  • Replies 73
Come on guys!!! We don't do this stuff very often so will be awesome to have as many as possible involved!
Was a fun day last time even though I was the only GTR*** :happy:
***Not counting the two R35s that showed up!
Edited by GTRKat
https://www.sau.com.au/forums/topic/307610-dyno-day/page/4/#findComment-5230470
Donnan has started a new thread with how to describe your payment. http://www.skylinesaustralia.com/forums/Sk...Da-t320081.html
Ross
Thanks for the link RP071!
Was a fun day last time even though I was the only GTR*** :laugh:
Hehehe not this time... :P
https://www.sau.com.au/forums/topic/307610-dyno-day/page/4/#findComment-5231305
Hi all
The prizes that we have lined up will not be for dyno queens. The prizes will be shared out. As we only have 30 spots allocated (which I'll be suprised if we fill) we already have over 25 prizes, so everyone that participates will receive something.
If this takes off then we will have this as an annual event and hold every year on the first Sunday in June. As you can see we (ACT Supra Club) have 13 names down and people are paying everyday as they don't want to get on our blacklist. We really need you guys/gals to get behind this event to make it into an annual thing.
Cheers
Ross
https://www.sau.com.au/forums/topic/307610-dyno-day/page/4/#findComment-5233214
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
