  • Replies 75
A quick go using the font from Mitch's logo (can't find the font) - good on a white or black bg
brake lights from R35
Welcome aboard Gust and good effort.......don't mind that one cause it's something different I suppose.
another couple of edits of my original design
2nd one looks better as the AU doesnt overwrite the blue, but on the second one the blue A intersects the border of the S. If you moved the A to the right a bit so it doesnt intersect it'd be better. I would also cut the blackness back to the white borders of the primary text, rather than having angular fill in. if you can get a decent printer to fabricate the stickers with a clear section, it'd be worthy - keep the symbols free floating with a transparent bonding layer, keep the borders but dont let them intersect each other, Max contrast and max transparency for the areas of the sticker that are not text
$0.02
-D
Let me clarify: This is not a change to the club logo, just a sticker for members to display on their car. The feedback we received for the current design wasn't exactly positive, so the right step for us was to ask the members to design a sticker.
I know i said "logo" earlier, but the logo will remain the same.
Ahh... so we're after a new sticker layout based on the current logo, and not a new logo.. is the current SAUSA logo based on the above ones you've been showing, Damien? I'm wondering what the current logo is to work with as a base.
Btw Dion invited me here :)
The new sticker can be based on your brothers toothbrush if you so wish, it doesn't have to be based on the current logo
not a fan of these designs at all. lol illustrator gone wrong and photoshop basic's we can do much better I should hope ??????
are we looking for a identity like the golden arches or just a sticker to replace the shite ones we have now ? something like the R31 club has, more of something to identify us at a glance, something that stands out from the crowd (sheep /muppets) but something that caters to the masses who join up ?
Some ideas based on the new skyline logo styling. As before, the thumb is on a black background, the full size with a white background.
the bottom one is my 1st choice with a close 2nd for the top one :(
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
