Harey Posted February 10, 2010 Share Posted February 10, 2010 Hi All, Just came across this turbo, it is a GT3076R turbo but made to bolt up directly to the skyline manifold and dump pipe. Only modification is to the water lines. They also do it for GT28RS, GT2871 or GT3071. Bottom of Page 2: http://horsepowerinabox.com/HPIAB2/category12_2.htm Seems very interesting although I spoke to Michael from GCG and his response was: "We used to do these bolt-on turbochargers, however, we ran into heavy boost spike issues, as the factory 6 bolt Nissan housing is just too restrictive and small on the back of a GT3076R. This was the case, whether it be machining the original housing, or using atermarket cast housings" Just wondering if anyone has used one or if anyone has any more information around them? Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/ Share on other sites More sharing options...
TiTAN Posted February 10, 2010 Share Posted February 10, 2010 get a real 3076, will make more power with less issues. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080561 Share on other sites More sharing options...
Harey Posted February 10, 2010 Author Share Posted February 10, 2010 (edited) Yeah thats my preferred option too, its just its $2k compared to $3k for the real one (complete kit) plus you need a new dump pipe etc. Edited February 10, 2010 by Harey Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080649 Share on other sites More sharing options...
bozodos Posted February 10, 2010 Share Posted February 10, 2010 what do you mean 'real' one, and what is the difference between this and the Hypergear one? Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080662 Share on other sites More sharing options...
TiTAN Posted February 10, 2010 Share Posted February 10, 2010 i am saying go a full Garrett spec one, rather than an aftermarket rear housing option. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080679 Share on other sites More sharing options...
Tangles Posted February 10, 2010 Share Posted February 10, 2010 Garrett dual ball bearing GT3076 internal wastegate: Garrett cartridge CHRA 700177-5015 Highly ported Nissan 45V4 front housing AVO .73 rear housing 6-bolt skyline style bolt on, $2300 with lines from Adelaide Turbo Services garrett chra pricing: http://www.turbobygarrett.com/turbobygarre...am_May_2007.pdf avo rear housing : http://www.avoturboworld.com/pdf/gts_exhaust_housing.pdf no boost spike was using a hks 14pound actuator but upgraded just now to a garrett 18psi turbo actuator boosts quicker and holds nicely at 1.25bar, no spike feels very powerful, will redyno test soon Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080693 Share on other sites More sharing options...
bozodos Posted February 10, 2010 Share Posted February 10, 2010 that sounds like the one Hypergear is offering tbqh well what do you mean Titz, are you just saying that the way the dump pipe flange is designed is the problem? Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080697 Share on other sites More sharing options...
tridentt150v Posted February 10, 2010 Share Posted February 10, 2010 A 0.73 rear is too small IMO. OK for making sub 250, but you will have issues over this. Anyway, much better off with an external gate if you want to make good clean power. An internal will do it, but you have to fight against it all the way, it is never easy. Just read all the threads on internal gate problems aka boost probs. Bite the bullet and get a real Garrett 3076 WG, around $2K plus water/oil and dump pipes. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080743 Share on other sites More sharing options...
That_timothy Posted February 10, 2010 Share Posted February 10, 2010 I also just found this earlier this morning. I've been reading this http://www.skylinesaustralia.com/forums/Ch....html&st=20 and I'm put off the idea a bit by Mafia, but I'd like to see what somebody thinks of these new sizes. Is it just a better idea to buy the 3076 they have here http://www.horsepowerinabox.com/HPIAB2/prod641.htm and then get the extra parts from somewhere else? The more I read on this the more questions I seem to be asking... Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080773 Share on other sites More sharing options...
TiTAN Posted February 10, 2010 Share Posted February 10, 2010 Is it just a better idea to buy the 3076 they have here http://www.horsepowerinabox.com/HPIAB2/prod641.htm and then get the extra parts from somewhere else? that turbo wont physically bolt up to a skyline manifold. needs to be T3 not T25. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080802 Share on other sites More sharing options...
paulr33 Posted February 10, 2010 Share Posted February 10, 2010 A 0.73 rear is too small IMO. OK for making sub 250, but you will have issues over this.Anyway, much better off with an external gate if you want to make good clean power. An internal will do it, but you have to fight against it all the way, it is never easy. Just read all the threads on internal gate problems aka boost probs. Bite the bullet and get a real Garrett 3076 WG, around $2K plus water/oil and dump pipes. agree 100% on internal vs external, re: good clean power external seems to be the way to go if you want good clean power and no issues check out roy's rb20 td06 setup, with his proper external setup (manifold, gate, dump) his setup is bulletproof and makes tons of power, even on the rb20 Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080820 Share on other sites More sharing options...
That_timothy Posted February 10, 2010 Share Posted February 10, 2010 that turbo wont physically bolt up to a skyline manifold. needs to be T3 not T25. Oh ok, there's a T3 they've got there too, thanks for that. But in general, is it going to be better to just buy something like this http://www.horsepowerinabox.com/HPIAB2/prod18.htm and then find the parts other people are recommending? Appologies if these are particularly stupid questions, I'm very new to selecting indivual parts for turbos. Cheers, Tim Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080821 Share on other sites More sharing options...
R31Nismoid Posted February 10, 2010 Share Posted February 10, 2010 Ye - forget the age old RB housing machined out, it is not big enough for a 3076. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080822 Share on other sites More sharing options...
TiTAN Posted February 10, 2010 Share Posted February 10, 2010 http://gcg.com.au/turbo/ViewProduct.aspx?ProductID=7 that is the model you want. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080838 Share on other sites More sharing options...
That_timothy Posted February 10, 2010 Share Posted February 10, 2010 Oh ok, So what'd be the ideal way to run this then? Again, sorry but until recently I was set on a HKS full kit, so all this is completely left feild Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080845 Share on other sites More sharing options...
Harey Posted February 10, 2010 Author Share Posted February 10, 2010 (edited) Edited: Woops misread post Edited February 10, 2010 by Harey Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080928 Share on other sites More sharing options...
Harey Posted February 10, 2010 Author Share Posted February 10, 2010 Bite the bullet and get a real Garrett 3076 WG, around $2K plus water/oil and dump pipes. GCG do the kit for $3k, so its a bit more than $2k. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080929 Share on other sites More sharing options...
Harey Posted February 10, 2010 Author Share Posted February 10, 2010 (edited) A 0.73 rear is too small IMO. OK for making sub 250, but you will have issues over this. 0.73 rear doesnt sound that small. Guys are making good power with the 0.63 housing. Yes the optimal is a 0.82 housing, but 0.73 isnt far off that! Standard R34 OP6 housing is what 0.5 something. Guys are making 250rwkw with a smaller trim hiflow wheel. Edited February 10, 2010 by Harey Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080933 Share on other sites More sharing options...
Haines Posted February 10, 2010 Share Posted February 10, 2010 (edited) I pissed my AVO 73 housing off as it didnt like making power and i had all sorts of problems with it put on a 82 external and it already feels better Edited February 10, 2010 by Haines Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080943 Share on other sites More sharing options...
l0WRB Posted February 10, 2010 Share Posted February 10, 2010 gt3076r turbo itself is around $1800 mark? then around $500 - 600 to fit with new dump oil/water lines intake pipe and cooler pipe pretty basic , 3k is way 2 much for a complete bolt on kit. Link to comment https://www.sau.com.au/forums/topic/307628-new-rb-nissan-special-garrett-gt3076r-ball-bearing-turbo/#findComment-5080951 Share on other sites More sharing options...
