  • Replies 42
Posted Images
Hi Guys
My GT35R is going in my R33 gtst soon and I need bigger injectors.
Should I run nismo 555cc or the 740cc?
is it bad to run bigger injectors then what is needed?
Cheers
Im running a GT3076R with Nismo 740cc injectors.
Its not bad to run bigger injectors then what is needed its just that it will probably eat a bit more fuel. 555cc will be enough but if your planning something big in the future get 740cc
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080717
Yeah I was leaning towards the 740cc anyways. Cheers mate. What kind of power are you producing? and where abouts did you get your injectors from?
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080723
I dont know where they came from because i got then through a car club that has their own suppliers. Right now im making 280rwkw but plan on more boost (need better boost controller) and hopefully over 300rwkw soon.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080737
Yeah I'll probably get them off nengun. 280 is a nice figure I'm hoping for somewhere between 280 - 300. What boost controller you using? I was going to go the eboost street.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080747
Im using the Blitz Spec S, should have gotten the spec R to say the least lol. Apparently one of the best boost controllers going around atm.
Oh and just for reference. Max injector duty im getting on 740cc injectors and 280rwkw is 60%
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080753
Lol I had a similair situation but with my fuel pump. Had a Walbro installed under the impression that they were great from my mechanic only to find out that theyre apparently crap. Oh well we'll see how it holds up.
You running a powerFC? i was thinking of getting nistune but don't know too much about them.
60% is pretty good, the 550's would probably be working overtime with a 35R.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080758
I'm running a GT3076 with 550cc Injectors and its pushing 300kw @ the rears comfortable.
With a GT35 you could easily hit 350-400kw like said above but its up to you how much boost you want to run.
If your running a GT35 you might as well go for 350kw minimum.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080778
True. At the moment i want to see how much power I can get out of the stock internals, manifold etc... Just with bigger injectors an ecu upgrade. When I'm satisfied I'll start boosting it lol.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080787
Trust me you will want more power if you know all you can do is turn the boost up and get 50kw more and still be safe.
I recon you should get the 740cc injectors if your going to go with the GT35, so you have the option of running more boost.
If you said you was getting a GT30 I would of said stick with the 550cc.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080801
I would have gone for a GT30 but my mate was selling the 35R cheap cheap brand new so i took the bargain.
You reckon 300-350 is achievable with a stock RB25?
Edited by LI51CA
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080815
I would have gone for a GT30 but my mate was selling one cheap cheap brand new so i took the bargain.
With a GT35 bolted on a stock RB25, 350kw is easy.
When you say stock, your talking about the RB25 internals right?
Because I have not seen GT35 bolted up to a stock RB25 manifold.
Every GT35 I have seen has been a top mount meaning the manifold has been changed.
I don't think you could even fit that turbo low mount.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080840
I'm talking about internals and manifold. It will fit, it just needs a spacer. I know a few people who have done it.
The only thing restricting me from reaching 350kw is heat generated from the stock manifold and lack of flow. This is why i said i wanted to see how much power I can get before i need to change my manifold etc...
Edited by LI51CA
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080859
Well then its anyone's guess on what power you will make according to your set up.
The stock manifold is very restrictive once your around the 280kw mark.
Let us know how much power you make with the 35 bolted on the stock manifold.
Will be intresting :)
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080886
This guy in this THREAD did something similair to what I'm doing.
I'll post up my results once it's all done HERE
cheers
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5080911
300-350 will kill your stock rb25 very quickly. That's why I'm running the safe 280rwkw ATM. Flow is a problem with the standard manifold that's why anything over 300 will be hard to make. I've had my manifold ported to gasket size. To answer you previous question I'm running a powerfc. Also if you haven't done so look into gettig a cam gear. Helps with response nicely
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5081975
That's simple, 280-300rwkw.
Plenty of people have been there and done it. I see no point in you trying to do something that's already done and proven time and time over.
You can make more than 300rwkw, however your motor will not hold together forever. Pointless excecise really.
If you have a stock motor, a GT35 is far to big. Get a proper sized turbo, a GT3076, and have a decent/responsive setup.
As opposed to one that will be laggy for the power you will make.
https://www.sau.com.au/forums/topic/307647-what-injectors/#findComment-5081989
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
