  • Replies 42
Posted Images
300-350 will kill your stock rb25 very quickly. That's why I'm running the safe 280rwkw ATM. Flow is a problem with the standard manifold that's why anything over 300 will be hard to make. I've had my manifold ported to gasket size. To answer you previous question I'm running a powerfc. Also if you haven't done so look into gettig a cam gear. Helps with response nicely
Cheers mate.
Off topic question, how'd you get the black rear blinkers, they look sick.
Yeah I was leaning towards the 740cc anyways. Cheers mate. What kind of power are you producing? and where abouts did you get your injectors from?
If you get stuck i got a set of new rb25 injectors. http://www.skylinesaustralia.com/forums/Ga...view=getnewpost
Cheers mate.
HAha they Arent black. I think the angle of the photo and shaddows caused it to look that way. Guess you could do it with that tint spray!
Hmm with injectors I probably wouldnt go for high flow stock injectors.
Damn. Nice pic then lol.
Yeah I read somwhere that they aren't the best. I think i'll stick to nismo or hks. More dollars...
will the standard hi-flow 740cc injectors do the same job as a set of say .. nismo 740cc? are there any known issues?
I would buy the blitz ones ($850) not the highflows for the power you are after.
I thought u had them up for $840.
Do they come with everything needed to just slap them in?
yeah sorry it was $840, i will put some pics up later, it is everything you need to install them.
35R on stocko engine seems abit pointless.
I would sell it and go with a GT30 like others have suggested. Its not use having a whole heap of lag and lack midrange to make the same rwkw was a much smaller and more responsive turbo.
Don't feel bad, this just happens to be the angriest forum in the UNIVERSE when it comes to whining about large laggy turbos... It seems as though peeps these days will change "what do you think of LED windscreen washers" threads to a "do you think my turbo is too big" thread..
Share the love people!!
im sure ns.com could help out there.
  • 10 months later...
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
