  • Replies 42
Posted Images
300-350 will kill your stock rb25 very quickly. That's why I'm running the safe 280rwkw ATM. Flow is a problem with the standard manifold that's why anything over 300 will be hard to make. I've had my manifold ported to gasket size. To answer you previous question I'm running a powerfc. Also if you haven't done so look into gettig a cam gear. Helps with response nicely
Cheers mate.
Off topic question, how'd you get the black rear blinkers, they look sick.
Yeah I was leaning towards the 740cc anyways. Cheers mate. What kind of power are you producing? and where abouts did you get your injectors from?
If you get stuck i got a set of new rb25 injectors. http://www.skylinesaustralia.com/forums/Ga...view=getnewpost
Cheers mate.
HAha they Arent black. I think the angle of the photo and shaddows caused it to look that way. Guess you could do it with that tint spray!
Hmm with injectors I probably wouldnt go for high flow stock injectors.
Damn. Nice pic then lol.
Yeah I read somwhere that they aren't the best. I think i'll stick to nismo or hks. More dollars...
will the standard hi-flow 740cc injectors do the same job as a set of say .. nismo 740cc? are there any known issues?
I would buy the blitz ones ($850) not the highflows for the power you are after.
I thought u had them up for $840.
Do they come with everything needed to just slap them in?
yeah sorry it was $840, i will put some pics up later, it is everything you need to install them.
35R on stocko engine seems abit pointless.
I would sell it and go with a GT30 like others have suggested. Its not use having a whole heap of lag and lack midrange to make the same rwkw was a much smaller and more responsive turbo.
Don't feel bad, this just happens to be the angriest forum in the UNIVERSE when it comes to whining about large laggy turbos... It seems as though peeps these days will change "what do you think of LED windscreen washers" threads to a "do you think my turbo is too big" thread..
Share the love people!!
im sure ns.com could help out there.
  • 10 months later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
