EDIT: I must be clear; this is a shortblock that i purchased here in canada. I have no ideas about it previous running condition or lack thereof. The guy who i bought it from said it had excellent compression, thats all.
So i pull the harmonic balancer and goto pull the timing pulley and i notice its kind of loose.
I finally jiggle it off and i see this:
Any idea what the hell happened? Looks quite severe. You dont just mash through a keyway like that easily... There obviously had to be a difference in torque on the crank between the rotating assembly and the timing belt for something like that to happen.
I dont think id trust the timing gear again...
Whats left of the pillaged key.
I think i can save the crank by milling the keyway straight through and making custom keys. There was no evidence of this at all when the harmonic balancer was on. Everything seemed tight and the bottom end spun nicely by hand. Any ideas anyone? Is the crank salvageable?
Edited by ST240
https://www.sau.com.au/forums/topic/307684-rb30-severe-crank-damage-pics/
Personally I'll bet the balancer bolt was left loose at some stage,,,the gear has moved in and out of the crank,,,killed a belt and the previous owned slapped it back together and sold it to you. That crank is in a bad way,,,normally I would be happy to fix it but thats very bad.
Neil.
:P . anyone have a crank?
I'm going to see if the crank is damaged otherwise. If not I am going to attempt to mill a keyway 180 degress from that set and i should be away.
PS: DiRTgarage can you please email me at andrem85 @ telus dot net and we can discuss futher. I can pm until i have a post count of 10 and i dont feel like spamming this great board up you folks have just so i can pm you back :D .
Edited by ST240
Mine did that from a bolt not being tight enough. Had a new crank keyway milled into the opposite side (180deg) when I was rebuilding my eng.
No probs, just be aware that the timing mark on the crank gear will be 180deg out.
Good to hear guys. Thanks so much for the replies! Glad im not the only one; and that the damage isnt the end of the world :) . I have the pistons out, working on the girdle right now. The rod bearings look slightly worn, but maybe its normal. I borrowed some telescopic gauges, a micrometer and a dial gauge from my machinist to measure it all up.
I'll post some pics up and see what you guys think.
Ok so with everything apart, here are some pics. These pics were the worst i saw. Some were worn like this, some weren't:
Rod
Another rod.
Center bearing. Seems like its getting some thrust wear. In any of the above pics, you can't actually feel the "wear" with your finger nail, you can just see it.
Last but not least, i measured runout. I removed all the bearings except the outter two which made sense to me, otherwise the other bearings might interfere, effectively lifting the crank up when it is rotated, showing less runout than there actually is. It was only out about 1.5 thou, which is 3.8 mm. Happy days!
So my big question to you experts is: replace the bearings, or not? I'm no expert so I'm not sure to what degree the bearings are worn. All I know is they don't look super prestine haha. I guess I might as well while she's apart. Futhermore, it looks like quite the rigamarole to mic out all the bearings so i might as well do that with new ones.
Edited by ST240
no. its 0.6mm
looks like its not had the oil changed for ages. or has had a lrg gas conversion and the oil has been nitrated. (acidified from the lpg and not using a lpg oil)
and yeah, loose crank pully. although ive not seen it happen on the timing gear, but rather the crank pulley key way.
it can be fixed pretty easily, you need to get a good quality ceramic tile. shape it with a angle grinder to make a dummy key. get a good mig welder and fill the dammaged part of the crank with weld, then linish it back to round and remove the tile, you will have a good strong keyway slot.
not ideal but provided the crank pully does not come loose again, will last forever.
no. its 0.6mm
I'd rather not weld anything at this point; Id rather machine a keyway on the other side. I think welding is last resort.
I made a typo. Its 0.038 mm no? Lol anyone else got an estimate? And to think we're trying to build engines here :) .
Futher to this damage, It looks like something got in one of the cylinders at one point:
But i think i can reuse that piston. What do you guys think? There was some slight scoring (you can just barely feel it with your nail) in the bore too upon closer inspection which I'm hoping can improved by honing. I don't know what amount of scoring is acceptable before you need a rebore. Can anyone comment?
reuse it?
at a minimum i would be binning the rod,s crank and pistons and starting with fresh items (good cond 2nd hand crank) with new rings and bearings, then you'll have a half decent engine...
Lol :) . I was just going to do a build on stock RB30E internals for a "low" ( :) ) power application for this summer then go forged/full build next summer. You don't think I should reuse anything?! That's a bit extreme no?
Hi.
What you need to do is take crank rods pistons to a machine shop who know what they are doing. Explain your situation to them re rebuilding in the short term and have them measure everything up and be guided by them- ask questions re honing and bore wear. Ive seen much worse pistons used succesfully in the past.
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
