Hey guys, decided to sell all of the parts I have collected over the last few years. Was going to go into my s14a, but I have other priorities now and need to sell these parts.
No stupid offers please! Please use PM only with your interest, first in with money gets the parts.
Im not trying to make money by selling these parts. All items have been discounted compared to what the sponsors are selling for, even if it is still Brand new. I have specified where i bought the parts from so you can do you research and compare my prices to the sponsors.
Located in Adelaide - Will post at buyers expense, Pick up is welcome.
Cheers
Stephen
ItemPivot Volt Stabilzer kit - Bought from BT Revolution
Condition Brand New, In Box, NOT FAKE! Genuine Pivot
Price $130 + Delivery
ItemDefi Din gauges (Water/oil temp, oil pressure) - Green back lit Numbering - Bought from BT Revolution
Condition Brand New, In Box, All sensors included, All wiring etc...
Price $600 + Delivery
Item Defi Boost Gauge in PSi White Lit numbering
Condition Brand New, In Box - PSi Model Very Rare in Australia. Psi Model was distributed for American Market I was told. No Sponsors sell these
Price $290 + delivery
Item Defi Control Unit - Bought from CJ Motor
Price $170 + Delivery
ItemGreddy Profec B Spec 2 electric Boost controller(Black) - Bought from CJ Motor
Condition Brand New, In Box, Everything Included, Sensor, Wiring etc......
Price $450 + Delivery
Item Greddy Remote switch for Profec B spec 2 boost controller - Bought from CJ Motor
ConditionBrand New, In Packaging
Item R33 GTR Front Brembo Calipers + Endless Pads
Condition Good Condition, Some Clear Coat Missing on One caliper. Approx 57,000kms, Resealed at 45,000kms, Endless Pads %70 left.
Price$1200 + Delivery
Item Blue Silicone Hose (25ft of 4/6mm hose supplied) It is the thermal flex hose as used by Turbosmart - Bought from Midnightmods
Condition Brand New, Still in Plastic
Price $100 + Delivery
https://www.sau.com.au/forums/topic/307686-quality-parts-for-sale-in-sa/
interested in the defi centre gagues.will these slip straight into & replace the factory centre gagues on r33 gtr? do they come with everything or do u need a seperate controll box?
Thanks for your interest mate. These will fit straight into the factory center gauges on a r33gtr. there is a picture actually of these gauges in a r33 skyline dash on the side of the box. In the picture, these din gauges are installed under the climate control on the r33 dash. These gauges come with everything required to fit it in, all wiring and sensors included. All you need is to provide your own water temperature sensor adaptor, and oil temp/ pressure adaptor to plug the sensors into. The water temp sensor adaptor can be the one you fit into your coolant hoses, and the oil temp/pressure can sensor can be fitted into your oil sandwich plate if you have one.
I have these adaptors for sale, but they are for sr20.
have a look in this link to see the adaptors i am talking about.
http://www.nissansilvia.com/forums/index.p...ttach_id=267395
http://www.nissansilvia.com/forums/index.p...ttach_id=267187
Let me know if you want the gauges! cheers mate
Edited by 200SX s14a
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
