Have swapped out my HRE wheels (which have the TPMS installed) for the stock wheels (which don't have the TPMS installed) about a week ago and have been driving around since.
one of the tpms sensors in the HRE wheels is damaged and always throws an alert
I am not however generating an error code for the set of stock wheels which do not have any sensors which I find unusual (not complaining)
what does everyone get when they put on their wheels without the TPMS normally?
https://www.sau.com.au/forums/topic/307706-tpms/
i believe it only checks for the presence of the TPMS sensors periodocally. ie. it will not throw an error straight away. one possibility is that you fit the new wheels, go for a 15 minute drive, park it back in the garage afterwards (where your OEM wheels are presumably) and in that time it communicates with the sensors on the OEM wheels stacked near the car. you then go for a drive again, then come back, it "resets" again. just a possibility. the other possibility is they are working fine (i hope so, because if so, i will be getting a set!)
https://www.sau.com.au/forums/topic/307706-tpms/#findComment-5085800
what is odd though is one set of wheels driven for a week now has no TPMS. I might be away from home for 12 hours or more on occasion and have driven for a couple of 20 min trips in the meantime.
you are corect though in assuming the second set is close by, maybe 5-6 m away from the car.
I take it if I got a second set of tpms for the track wheels that these would have to be paired up with a consult III and that tpms sensors are not swappable in the way that different bluetooth devices recognise phones in order of preference and availability? I am not sure exactly how they work and neither are the boys at my dealership.
Anyone now of a cheap place locally for TPMS by the way? I know of an ebay international vendor that sells them but wondering if any available locally
https://www.sau.com.au/forums/topic/307706-tpms/#findComment-5085924
if i were to drive to the track with 18's i get the error yep.
however if i swap them on at the track (with the OEM wheels in the garage at the track) i dont get the error (because of the reason mentioned above). frequent visits back to the garage (where the OEM wheel/tyres are) tricks the system into thinking they are on.
is there any chance that your error you are getting with the TPMS sensor needs a reset, and the system isnt throwing any more errors until that is rectified?
https://www.sau.com.au/forums/topic/307706-tpms/#findComment-5086153
hmm, will see. week and a half with no error. the error code from the faulty tpms in the separate set of wheels in the garage used to come on daily, now none. That sensor was not installed correctly and was found free, rattling around in the wheel for a week until I could work out what the sound was so I think the error is due to physical trauma.
https://www.sau.com.au/forums/topic/307706-tpms/#findComment-5087824
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
