Then it sounds like the problem that I addressed in the first page of this thread, You need to remove the wheel, boss and all and compare the slot in the boss with the standard wheel and there will be a difference. the sensor must be positioned exactly central on the hole in the boss, and using foam and or tape to fatten up the prong on the sensor worked perfectly for me and many others.
Have you tried this??
sorry buddy i have not tried this yet although im not sure what the hicas sensor looks like.
Ive had the wheel off and im not sure what the hicas sensor looks like :P
Fark............ I just spent 20 minutes replying to this in a funny and witty manner with many references to male and female genitalia included and the whole lot was lost when i posted..................... GRRRRRRRRRRRRRRRRRRR I have to cook dinner now and then work on my car.............:crazy:
Any way the attached pic shows the rear view of the standard 33 wheel. the highlited hole is the nice tight girly bit that the hicas dick fits into...... the aftermarket boss has a larger slot and the dick floats around in it too much resulting in the sensor being off center when you are driving in a straight line.......... so fatten the part that fits in the affore mentioned hole using electrical tape to create a tight fit and bob is your uncle.....
failing that i can explain at MAS if you still don't understand, don't be shy not everyone is expected to be proficient at the art of vehicular modification.. ;)
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
