Im from the NA section, and my DE shat itself the other day and im going to chuck in a turbo.
Questions are;
- Things needed;
- Engine
- Turbo
- dump
- exhaust (manifold etc).
- Intake piping etc and intercooler.
- Turbo engine wiring loom (i assume?)
- Turbo dash
- turbo ECU
is there anything else im missing?
ALSO is it possible to fit a RB20det into a R33 up against the 33 5-spd manual? i can get a cheap 20det which is in VG condition and money is scarce so getting this engine might be the best option..
so can it be done? does it mount up? will the engine loom integrate? can i use a 33 dash?
Thanks for your help guys. i want to get this car back on the road, and when i start the swap i'll make a thread following the progress.
https://www.sau.com.au/forums/topic/307828-dropping-in-new-engine/
@NYTSKY
I thought that, but at roughly $4k for a front cut, i can get nearly everything i need for $1500 with a good searching of the For Sale forum, like i was saying, money is a bit tight and i need the car back on the road asap (old engine is gone).
Thanks for the idea though
It's going to cost $1500 just for a good condition RB25 + loom at the very least.
You expecting the rest for free or something?
There is no way you are going to get a RB25DET in, running, with the full cooler setup, exhaust etc etc for $1500 mate.
Front cut is the easiest way to go, and overall cheapest.
Then sell off the parts you don't need. Struts, panels, A/C components, brakes etc.
Fair, i might be a bit idealist with $1500, i've seen decent rb25's for $1000 .. so hoping for some good deals, get the exhaust and intake piece all stock, but your right, i'm gonna be looking at a bit more.
Though in terms of bits and pieces, is that all i need? or is there something im missing?..
Also, any thoughts on the RB20 install? straight bolt on the gearbox? is that right?
Hassles with installing it into a R33?
Thanks guys
Hey mate,
Get a 25det - I have obtained a bare engine for cheep and am slowly building it up, a lot of your NA gear is compatible (CAS, AFM, alternator etc) so that will save you some money. It's not that expensive, I have gone for a lot of aftermarket bits and that is the reason why I'm down a bit of money, however if you want everything stock your looking at $2000 (DIY).
agreed, between you (mr massive) and nismoid, $2000 is a pretty good guesstimate with getting good prices on all parts.. but i am having trouble sourcing them all, and i need the car quick.
And the rb20 isnt such a bad engine, mate has a r32 gtst and it goes pretty good, bit more powerful then then rb25de... not as torquey i'll admit but, for the cost factor, i can get the rb20det, including turbo and manifold for $500 (good condition motor, not stuffed) off a friend.
So thats why im considering this option, im not fussed with getting the best spec'ed engine. So after that i'd need engine loom for rb20det, ecu, intercooler and piping ofcourse, exhuast from manifold back. and thats it right?
Would the R33 turbo dash work with the rb20det anyone? and is there any complications i dont know of?
Thanks everyone again
UPDATE: alright, i've sourced a good S2 RB25DET, they've included;
- intake manifold
- exhaust manifold
- turbo
- loom
- ecu
- exhaust
- intercooler and piping
Questions;
- Any bits im missing? anything you guys can think of?
- Do i need the Turbo dash? or will it plug up ok and i just wont have the Boost Gauge?
- On my car i dont have the Aux thermo fan, do i need it on the turbo motor?
- Can i use my DE AFM and Airbox or do i need DET units?
- Does the fuel pump need changing?
Any comments you guys have are welcome, everything said so far has helped and is much appreciated... ill be getting the motor in 2-3 weeks, picking it up from Sydney.
I'll be re-freshing the motor with gaskets and the likes, and getting the head cleaned up before i chuck it on the car... so i'll do a little write up of refreshing the motor, the head work done and the install.
Thanks again to everyone
Edited by darkrams69
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
