Hey all,
Im looking to purchase an exhaust in the near future.
Ive been looking around and it seems, for example an apexi N1 cat bak will cost over 1k in aust and in japan around the 600 mark. But to get it sent from japan will cost around 600 itself!
Anyone know of any places that could help me out with? :)
Thanks
Brendan
https://www.sau.com.au/forums/topic/30784-purchasing-an-exhaust/
Look around the forums for someone selling one second hand.
Use the phone and ring some Australian wreckers, UAS, JustJap, etc.
Talk to some of the very many Jap parts importers around these days. Talk to supra man on these forums, try Nengun, Greenline, etc.
Hope that helps.
to a commended exhaust shop and get the system there. May have to get a stainless muffler from somewhere else but where i got my exhaust done they were really good. Dont need to buy bolt on kits from japan. But personal choice i guess. I would bother with full stainless but thats me
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
