If the wastegate (integral or external) is on the exhaust side...
And the build up air/pressure is on the intake side...
Then... How does the pressurized air from the intake side get to the exhaust side without going through the motor because you have lifted of the throttle?
lemmy try
when u lift off the throttle, build up of pressure happens on the intake side, vaccum line (to register boost pressure) to the wastegate registers pressure pushing on the wastegate diaphram opening it up
but, when we were dyno tuning my car i didnt notice any evidence of this happening while i was watching the wastegate actuator
https://www.sau.com.au/forums/topic/30788-bov-sound/page/3/#findComment-630670
  • Replies 50
BTW my comment to drifto was re the bullshit. I must admit that I didn't read his whole post at the time. I have now read it and he seems to have confused wastegate with BOV in his first paragraph.
R31Nismoid you are right to be confused by his post.
https://www.sau.com.au/forums/topic/30788-bov-sound/page/3/#findComment-630680
that makes it alot more audible as iv noticed
yep, my mates rex didnt make the flutter noise at all, then as he got the fmic he also got that metal pipe... Now it flutters... His pipe also has a 90 degree bend in it which will make the flutter more noticable.
https://www.sau.com.au/forums/topic/30788-bov-sound/page/3/#findComment-630728
im well aware of that :D
considering the amount of :bs!: on the forums... drifto did well in his post i think
but james... opening the wastegate no worries, but what exhaust is it bypassing if the throttle is shut?
yeah, a little bit... but by no means a lot like an RB at full song :D
and go the metal intake pipe, it rocks.
https://www.sau.com.au/forums/topic/30788-bov-sound/page/3/#findComment-630930
i say leave the flutter noise for the vls, from wat i know, even if the 'flutter' noise does not damage the turbo(which has yet to b proven), it WILL induce MORE lag than wat the car had wif the factory BOV. it will be especially noticeable will coming on boost and on gear changes, thats y cars hav BOVs to reduce turbo lag, now if u wanna sacrifice that for a pigeon like noise(i dont c why it is so popular) than thats up to u, but i for one prefer a solid pssshhhh.
https://www.sau.com.au/forums/topic/30788-bov-sound/page/3/#findComment-631230
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
