want to know a little bit more info about it?
heres the first website that comes up when you put car flame thrower kit into google: http://www.zorst.com/faq.html
and it says:
"How do the Flamethrowers work?
The flame thrower kit safely lights up fuel coming out of the exhaust pipe at the tip, using our proprietary flamethrower control module the kit works in with your vehicle to get the right mix for a flame when you want it, the flamethrowers can be turned on and off by a switch that you can fit in a convenient place. When not in use the flamethrower kit will have absolutely no effect over the regular performance of your vehicle."
but then.. if you google how do these things work, on this site: http://hackaday.com/2006/03/03/exhaust-flame-throwers/
it says:
"...Here’s a hack that’s been around since the very start of the hot rod movement. Car exhaust flame throwers work by interrupting the spark to the engine. This dumps raw fuel into the exhaust system. The fuel is ignited by a coil and spark plug placed right before the exhaust tip. Doing this will shorten the life of your engine (and pedestrians). The raw fuel strips the oil off the cylinder walls and contaminates the oil causing more wear and tear. Also, this mod can’t be used on a fuel injected car. It would foul the O2 sensors and catalytic converter. Never the less, our fascination with electricity will live on."
so need to know alot more info about the kit because a manufacturer says its fine for your car (their kit atleast) while 3rd parties are saying it can't work with fuel injected cars and is bad for the motor... so more info on the kit please!
Adam
brand?
pics of kit please?
I can't remember of the brand as i bought ages ago like 3 years ago :D but if i can recall it it's call "Flame Thrower"
The pics of the kit as below
PM me if you're interested.
and it says:
it says:
Adam
Hey Adam,
Sorry i can't help you much on that one as i've never really get a chance to install it in my car but as i remembered from the company i bought from he pretty much said it works on any car and i think you can control the level of flames as well.
Thanks anyway mate, done a few quick searches and this is what has come up:
http://custompinoyrides.com/2010/01/how-to...me-thrower-kit/
"Generally speaking, there is an exhaust flame thrower kit for any gasoline-engined vehicle with a distributor or coil. However, it used to be impossible to get this to work with a fuel injected vehicle.
If you’re mechanically and electrically inclined, then you can purchase the parts and do the installation yourself. Here’s how to DIY a Carb Engine Exhaust Flamethrower System.
But if you run a fuel injected engine, it’s a bit more complicated to DIY the installation, as you will be unable to force the engine to dump excess unburnt fuel onto the exhaust pipes.
But don’t fret, as there’s an Exhaust Flamethrower Kit you can purchase which has all the required gear, including a control module which will produces the unburnt fuel by momentarily interrupting the engine’s ignition system.
Just note that doing this will accelerate engine wear as you’re pumping excessive raw fuel through the engine which washes down the cylinder walls and also contaminates your oil. It will also eventually destroy your catalytic converter. Make sure you do an oil change more often."
And this too:
http://custompinoyrides.com/?TpYNXZ3T
"Q: Will I have to remove my
cat converter or do any modifications
to my engine?
A: In most cases you will have to gut
or remove the cat and replace with
straight pipes to produce a flame with
our kit. Check with your local laws and
regulations."
So while I think it would be cool, unfortunately its going to wear down the motor I have put a fair few $$$$'s into and means my 1 year old $300 cat has to be removed and if a cop ever saw u with 1 AND no cat so the flames will work... the fines will outweigh the cost of owning it like 10 or 20/1..... or more....
Just some info for fellow sau'ers to think about :nyaanyaa:
Adam
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
