want to know a little bit more info about it?
heres the first website that comes up when you put car flame thrower kit into google: http://www.zorst.com/faq.html
and it says:
"How do the Flamethrowers work?
The flame thrower kit safely lights up fuel coming out of the exhaust pipe at the tip, using our proprietary flamethrower control module the kit works in with your vehicle to get the right mix for a flame when you want it, the flamethrowers can be turned on and off by a switch that you can fit in a convenient place. When not in use the flamethrower kit will have absolutely no effect over the regular performance of your vehicle."
but then.. if you google how do these things work, on this site: http://hackaday.com/2006/03/03/exhaust-flame-throwers/
it says:
"...Here’s a hack that’s been around since the very start of the hot rod movement. Car exhaust flame throwers work by interrupting the spark to the engine. This dumps raw fuel into the exhaust system. The fuel is ignited by a coil and spark plug placed right before the exhaust tip. Doing this will shorten the life of your engine (and pedestrians). The raw fuel strips the oil off the cylinder walls and contaminates the oil causing more wear and tear. Also, this mod can’t be used on a fuel injected car. It would foul the O2 sensors and catalytic converter. Never the less, our fascination with electricity will live on."
so need to know alot more info about the kit because a manufacturer says its fine for your car (their kit atleast) while 3rd parties are saying it can't work with fuel injected cars and is bad for the motor... so more info on the kit please!
Adam
brand?
pics of kit please?
I can't remember of the brand as i bought ages ago like 3 years ago :D but if i can recall it it's call "Flame Thrower"
The pics of the kit as below
PM me if you're interested.
and it says:
it says:
Adam
Hey Adam,
Sorry i can't help you much on that one as i've never really get a chance to install it in my car but as i remembered from the company i bought from he pretty much said it works on any car and i think you can control the level of flames as well.
Thanks anyway mate, done a few quick searches and this is what has come up:
http://custompinoyrides.com/2010/01/how-to...me-thrower-kit/
"Generally speaking, there is an exhaust flame thrower kit for any gasoline-engined vehicle with a distributor or coil. However, it used to be impossible to get this to work with a fuel injected vehicle.
If you’re mechanically and electrically inclined, then you can purchase the parts and do the installation yourself. Here’s how to DIY a Carb Engine Exhaust Flamethrower System.
But if you run a fuel injected engine, it’s a bit more complicated to DIY the installation, as you will be unable to force the engine to dump excess unburnt fuel onto the exhaust pipes.
But don’t fret, as there’s an Exhaust Flamethrower Kit you can purchase which has all the required gear, including a control module which will produces the unburnt fuel by momentarily interrupting the engine’s ignition system.
Just note that doing this will accelerate engine wear as you’re pumping excessive raw fuel through the engine which washes down the cylinder walls and also contaminates your oil. It will also eventually destroy your catalytic converter. Make sure you do an oil change more often."
And this too:
http://custompinoyrides.com/?TpYNXZ3T
"Q: Will I have to remove my
cat converter or do any modifications
to my engine?
A: In most cases you will have to gut
or remove the cat and replace with
straight pipes to produce a flame with
our kit. Check with your local laws and
regulations."
So while I think it would be cool, unfortunately its going to wear down the motor I have put a fair few $$$$'s into and means my 1 year old $300 cat has to be removed and if a cop ever saw u with 1 AND no cat so the flames will work... the fines will outweigh the cost of owning it like 10 or 20/1..... or more....
Just some info for fellow sau'ers to think about :nyaanyaa:
Adam
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
