r33 coupe. only bought this in june. going to tafe so dont really have time to enjoy the car whilst studying and working lots to get by.
94 series 1.5 grey coupe.
149000 k's
'drift'? brand steering wheel
ceramic clutch
35% tint all round
3" turbo back exhaust(knocked through cat)
100-120mm thick cooler i think from memory. well its big anyway with full piping setup
hks mushroom pod filter
lowered tien spring all round
avs model 5's. 18 x 8.5 and 9.5 +38 resprayed black 2 weeks ago. approx. 80-90% tread left all round
boost gauge
pioneer head unit
walbro 225 EFI fuel pump
auto watch alarm
white face dials with blue backing globes on dials and interior light
hicas lock bar setup
resprayed the mirror and rear spoiler at christmas
aftermarket spoiler
Really good working A/C!!!
nothing much more to do. all support mods done ready for you just wind the boost up if you wanted to hassle free
also have a spare set of the same rims in silver i can swap and put on the car if the buyer prefers
receipts for all work done since ive owned it
located southern suburbs
think thats about it. most of the stuff has been done since ive owned the car
will consider trade plus cash for daily cars so throw up some offers if you want.
$12,000 ph 0422603195
https://www.sau.com.au/forums/topic/307897-r33-15-grey-coupe-with-mods/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
